T whiting
There good for f****ng grass too
Yeah tend to 'nip' the fairway crossing a golf courseThere good for f****ng grass too![]()
gripping geo ?????Is there anything those Geogrip pads are good for?![]()
gripping geo ?????![]()
Well they stop the old man shouting at me for tracking steel tracks across the concrete yardIs there anything those Geogrip pads are good for?![]()
Now finally seen pics it's a 204 so won't do above 4 tonIts a 206 but not ec-oil. Buckets are too small for a larger machine.
His is a 4 hose system if that makes a difference to the hose layoutNow finally seen pics it's a 204 so won't do above 4 ton
Pic of my old unit and new one you oil feed and return is run over top of tilt ram where's mine are not
4 hose 206His is a 4 hose system if that makes a difference to the hose layout![]()
Also know as road liner tracks as well James, predominantly used on 8ton+ machines, turning them into rubber tracked machines, Komatsu and Hitachi offer them as an option, youโll find them mainly with utility excavators that are working on tarmac.Is there anything those Geogrip pads are good for?![]()
What a lovely instal
They track and turn nicely on the right ground but can slide everywhere - damp grass is a nightmare! I nearly went for them and steel tracks but glad I saved the extra 2k and went for the jack of all full rubbers!Is there anything those Geogrip pads are good for?![]()
Did you sell it Fred. I might be after something similar in the near futureOnce the current job is done shortly I've decided to move on the kubota as I'm going to a 5/6/7 tonner. Thought I'd put her here first before the dealer as a trade in.
KX030-4 High Spec, 300 hours. 2 years old September, balance of Kubota warranty.
Engcon 206 S40 ith grab, 600 engcon bucket with teeth, 600 BMC smooth bucket (used once bloody archaeologists) Engcon grader, Engcon 300mm drainage 750 deep, BMC ripper tooth. Also got a brand new unused whites top hitch never used that will throw in.
Also have the indespension Alumax trailer as new, used 6 times.
Open to sensible offers that beat the trade in (wont be sorted until after this corona madness ends). Can come and try it out and kick the tracks no problem, located worcester.
Here is when she was picked up. Still in great nick, seat has 2 covers on including the plastic from the factory!
