F
fred
dittoIf my lottery numbers come up......I will give you a call!!
Will be interesting to see what numbers you get offered as that looks to be an ideal set up.
Iveco daily , can pull 3.5Looks tidy,what's the van your towing it with?
Did you decide not to keep the engcon then ? Didn't someone say s40 will go onto up to 6 ton machine.
S40 is plenty strong enough for a 6 tonner...
The only downside is you can’t get oil-quick/EC oil etc unless you go up to S45, but that’s a much heavier/deeper setup.Be lovely and light on that too I would of thought
You dont hear people talk too much about the extra weight - I have a Geith tilt ditcher on the 8t that is 390kg and that takes a fair bit away from the machine - what would a setup like that on the KX57 weigh ?The only downside is you can’t get oil-quick/EC oil etc unless you go up to S45, but that’s a much heavier/deeper setup.
Exac-1 had a really nice KX-57 set up with an Engcon on S45 with a top and bottom hitch/EC oil etc - on paper it was great but compared to my S40 6 tonner was a really cumbersome lump on the end of the dipper IMO. Too much for the base machine with top and bottom hitch, probably ok direct mount though.
I dont think its the S40 bit thats the problem. Its the unit itself, I think Fred has an Ec204 which would be rated to 4t class excavator. He needs an EC206 but could still spec it at S40 and keep some of his attachments. Its a lovely setup though and will do someone proud. Shame about the Kubota though![]()
are those steel tracks on there Aiden .... with presumably rubber blocks added ? No grousers though ?6.5 ton Hitachi zx65 Hurricane T-lock S40 top hitch. Rototilt R2 S40 with gripper. Hurricane TB6 1.2m 250L grading bucket. Handles it really well
Geogrips.... Not bad pads at all, but look s**t after not alot of time if working on rough ground.are those steel tracks on there Aiden .... with presumably rubber blocks added ? No grousers though ?
Geogrips.... Not bad pads at all, but look s**t after not alot of time if working on rough ground.![]()
There a interesting one, We got our set FOC with our second machine as they had been off a cancelled order.... Can't say they have thrilled me and after 500hrs already look crap, BUT they are handy for what they are needed for.What he saidand the exact reason there is a new set on there.... the old set looked real tatty... even though they were decent enough.
Proper steel chain with bolt on rubber pads, good job and got a cracking deal on these which is the only reason there on there.![]()
