Antony Holmes
dig a track across a playing field some one has to clean it upWhy are you guys brushing grass? Have I missed something here?
Ahh that makes sense. I usually put polythene down for that kind of task. Its awkward if you catch it when back filling but quite clean if you're careful. Havent thought about sweeping it. Learn something every daydig a track across a playing field some one has to clean it up
An accessory I would really like is a deep bucket that rests on the floor as it would be too heavy to lift when full, but is held in place by the digger.
It has a pump running from the digger hydraulics, 150mm pipe connection.
Concrete wagon could empty into it and it would pump through the pipe.
Every small builder would buy it.
The same as a concrete line pump?An accessory I would really like is a deep bucket that rests on the floor as it would be too heavy to lift when full, but is held in place by the digger.
I generally go for £25-30per hour depending on job and how long. I only work flexible hours to suit me as I have child care commitments!!
rates are always a bone of contention on any public forums saw one on face book the other day all sorts of comments from i would not get out of bed for that to how can you charge that you have some nerve i try and get £27.00 most of the time on a steady hire some times have to drop a bit in January for a couple of weeks on day jobs i will do a day rate but it all works out over the month/year
i see 2.5 ton machines out at £21 but not me
Best bet is to pick up the phone and talk to the suppliers direct. Tell them from outset you simply want a ball park figure.
As Rob says above - talk direct. The three main companies in the UK (in the world, for that matter) are us (Engcon),Rototilt and Steelwrist.
Call all of us and ask the question. Engcon's landline is 01684 297168 or if you would like to talk to me direct, please call 07702 167809
regards
Robert
I've always wondered why they don't make heated seats on micros and dumpers. Would make quite a big difference to using them all day in winter. But I guess its a cost thing again.Plus winter is coming and sitting on the micro sucks balls. Last year every lock had frozen on it and the seat was like a block of ice that was a twat of a day.
