that'd be a full tank of juice and a full tank of LPG'd do that ... 80 ltrs in eachIt looks like he left his wallet on the back seat thoughsquatting a bit
" Specialist contractor fuelled by veg oil "
When they first came out a mates dad sold his before it was even built so called doubled his money and a bit more then went back on the waiting list, apparently it was relatively common thing at the time.aye ..... bitterly regret selling it ...... chassis no 964, 1970 on a J plate .. one previous owner ... an aircraft engineer who was fanatical about it .... had two lever arch files of history with it and a box full of receipts for petrol![]()
..... he kept everything to do with it ... and a meticulous log of every thing ever done to it, as though it was an aircraft maintenance log.
IIRC it was about1900 quid and change when he bought it..had the original receipt ...
came from Branksome .. a customer of mine put me on to it ... his Uncle's, who had died and it was in bits, when I collected it .. put it back together and used it for a couple of years ... drove like a new one ..
when they came out, any Giles that bought one, after a SII must've thought they'd died and gone to heaven![]()
Don't get why hydrogen fuel cells were dropped for battery bullshit more so in large kit that has room for it and only emissions is water![]()
Hyundai plans hydrogen-powered diggers by 2023
Hyundai Construction Equipment plans to bring to market an excavator series powered by hydrogen fuel cells.www.theconstructionindex.co.uk
my guess would be safety Stu ..... hydrogen is one of the most volatile elements on the planetDon't get why hydrogen fuel cells were dropped for battery bullshit more so in large kit that has room for it and only emissions is water
So is a broken fuel line and a source of ignition if conditions are rightmy guess would be safety Stu ..... hydrogen is one of the most volatile elements on the planet
agreed ..... the batteries are just bombs in a n other guise ....So is a broken fuel line and a source of ignition if conditions are right
Have you seen all the let's crush a Lithium battery vids on YouTube
Need to perfect on-demand hydrogen systems so it's just a tank of water and small amount in converter and fuel lines
If i could answer that i wouldn't be digging holes for a livingHow do you split the hydrogen from the water without electricity?
No such thing as a free lunch.
well while you're sat pulling the sticks and contemplating that question ... give some consideration to - how to recycle tyres ... you don't have to do it, just come up with a great idea, on how and sell that .... first one to come up with a solid, profitable, simple solution will be a billionaireIf i could answer that i wouldn't be digging holes for a living
This is where green energy is coming into play. Apparently they are taking up the surplus at certain times of the day to make the process cheaper.How do you split the hydrogen from the water without electricity?
Yes but then you have to have the hydrogen in a tank on the car- in relation to Left Hookers comment about on-demand hydrogen systems.This is where green energy is coming into play. Apparently they are taking up the surplus at certain times of the day to make the process cheaper.
??????????This is where green energy is coming into play. Apparently they are taking up the surplus at certain times of the day to make the process cheaper.
It was a while ago that I heard about this but it is making a lot of progress.??????????![]()
interesting read Shaun ... electrolysis would look to be the best and most efficient, if ultra cheap leccy can be used .... but gaseous H2 is massively risky for handling and storageIt was a while ago that I heard about this but it is making a lot of progress.
Methods of Producing Hydrogen at Scale | Royal Society
This policy briefing considers how hydrogen could be produced at a useful scale to power vehicles, heat homes and supply industrial processes.royalsociety.org
