Jcb loadall
Jigsaw G
Hi 👋 can anyone help I’ve got a Jcb 1994 loadall 530-120 and only one of the stabilising legs is now working, has anyone any ideas what the fault is, we have checked fuses and hydraulic oil, many thanks
Is there a solenoid valve on the line that locks it off when the boom is above a certain height? Maybe an issue with that
or a solenoid valve per leg, one of which has bitten the dust :(
if it were a boom height issue I'd expect both legs to be non-functional
Steve
Could also be a relay between your button or switch & solenoid.
jd6820
jd6820
Mechanical limit valves on a machine that age. Plunger operated job, as electric wasn't common on that age of machine. I'd bet one of the plungers is stuck. A tap on valve and some lubrication job should be a good'en. One for each leg, hence the fact one is still operational.
jd6820
jd6820
Here is a picture showing valve location. I’d start there make sure the oil is being allowed through the valve.
Jigsaw G
Thanks👍
Exactly this👆 they are located near the boom hinge point behind the cab. Sometimes the little roller bearing breaks causing this.
Jigsaw G
Thank you so very much for this valued information, I will give this a try, you have been most helpful which is appreciated, Graham
