diggerjones
The digger had lost power on the road. At the top end revs.
That was my first thoughtMaybe air filter blocked![]()
Well it lives again. Wasn't straight forward, i took the filter out of the fuel pump to clean which needed it. But i think i must have got the spring and the little plug wrong way round. Anyway bit of messing swapped it round sorted. Test run up the road, going really good, then stopped
I hadn't turned the fuel back on![]()
Yes. But fuel on the road, not good. And luckily i was not in a bad position.The sence off relief when you realise that's all it is![]()
