Jason pendry
Hi
I have a 6 ton dumper , I had problems with water getting into starter so stripped off , then noticed that had oil and water in gear box so stripped off to clean , when I have put all back and started up then selected forward gear went forward and backwards turned it off and now won’t go forward or backwards
When I push the stick forward on the the column it does not start lie it is in gear
All help will be good
