Tidy work....mental note made of the scaffold tube trick!!
I’ve found out that if you go into the “edit” section of the picture, rotate it 360 then save it, it comes up right??...but then there’s no rhyme or reason for when it does it??.....it’s a bit like through a six to startSo how the hell do I get photos taken in portrait to download on the level?![]()
I upload everything from an iPhone, not sure if that has anything to do with it?
Looks like harford safelockWhat have I gone and done now
Saw a pecker to fit a mini digger advertised locally and only gone and bought it
Turned out that a local 'car dealer' was selling it and has tarted it up with a splash of yellow paint
So, I knew all along that the head stock with it's 40mm pin was no good for my 32mm pins quick hitch........
......but considered it a work in progress
So does anyone know what this head stock is for
So here's the thing, I have now managed to ID this 'new toy' as an Arrowhead S20 and downloaded the spec etc
And I now thing that it may be too effing big for my Neuson 1503
Flow rate should be 25-40 lpm whereas my machine puts out 23 + 23
I will contact @Dr pecker shortly for some advice ......
Yep got to to add to my Certified lifting eye on my ‘new’ Harford quick hitch
Looks to me like an Asian market machine? No check valves and style of bucket. I think Volvo are still producing b series machines for some markets and we are on e series over here, could be the same for that Case?Why would you buy a machine like that and only put 33hrs on it? Surely that hour meter is broken!
Nope spoke to Nigel yesterday about my peckerYou mean 2004 for the case?
'cos it's ex military new old stock. Speaking to Nigel yesterday about my old peckerWhy would you buy a machine like that and only put 33hrs on it? Surely that hour meter is broken!
That makes sense. The MOD buy loads of plant just in case and never use it. Those 33 hours are likely to it being started up to service it each year. I see plenty of plant on bases with the paint still on the bucket teeth.Nope spoke to Nigel yesterday about my peckerand he confirmed that it is an ex military new old stock job from 1994
