LED Lighting
dhas
dhas
A mobile operation offering LED light bars, work lights, strobes, beacons, LED warning bars and the works. And when the sun shines sprayer testing. Shipping all over Ireland and fitting available.
wee_gus
wee_gus
What can you offer for my van, currently got 27w spots but not feeling them! I want some bright!!
my 48W, eyeball burningly bright cheap an' cheerful (less than 8 quid a piece) chinky /ying tong LEDs are some bit bright ../.. like daylight :giggle: and at the price you just bin any faulty ones (which hasn't happened yet) these aren't the same supplier but look the same unit
serious illumination :giggle:(y)(y)
I have them on my machine but a few leds have failed now😩
wee_gus
wee_gus
This is what I’ve got
wee_gus
wee_gus
Yea potentialy, not for rear as they double up as reverse lights
dhas
dhas
70 watts from 56 x 1.2 watt Philips high quality led chips. (performs like a 100watt led light)
Voltage range 9 to 36 vdc
Size 270 wide x 93 height x 62mm depth ( height changes to 107mm to include bracket )
Massive 9320 lumen
LUX: 56 @ 10m
270mm x 61mm x 106.5mm
Diffused flood beam available with 140 degree angle of light spread
Unbreakable Lexan ploycarbonate from lens cover.
Patented ETM technology
Light transmittance is an impressive 95%
EMC electrical interference protection to CISPR25 CLASS 4 levels
Includes mounting bracket and DT connector.
dhas
dhas
For the reverse 🤔
12-24 Volts
Size: 155 x 109 x 73mm
15 x 3 Watt LEDs
45 Watt
Flood Light
Pre Wired with 2 Core Cable
Cast Aluminium Housing
3000 Lumen
1.4 Amps at 12 Volts
Left hooker
Left hooker
Would hang off getting anything from China right now 😷
