Tree shear or grapple saw?
Will_c
Will_c
What’s the general consensus on using a tree shear or a grapple saw for general hedge and tree trimming, particularly reducing overgrown hedges?
Tree shears are simple, only require one hydraulic line and are considerably cheaper. The main downsides I can see are that they leave a rougher cut and you can’t use them to grab and move the brash once it’s been cut.
A grapple saw gives you the option of using a general-purpose grapple with a saw cassette mounted on the side. However, this would require more hydraulic lines and would be significantly more expensive.
Has anyone run either directly on the machine or underneath a tiltrotator?
If it's overgrown hedges in farmers fields then the quickest thing is a circular saw. They leave absolute devastation behind them where as a grapple saw or tree shear can pile everything as they go. But they are quick and a telehandler can tidy up behind them.
You need good hydraulic flow for a grapple saw, they only work in clean material (no good if grubbing stuff out at ground level), there is a risk of chain-shot (so need massive exclusion zones and marguard screens on the machine), and they are very expensive.
Shears can leave rough cuts (particularly if you are cutting near/above capacity) but that’s not necessarily an issue if you are knocking back a hedge that will ultimately be flailed in future.
Cut and hold shears make it easy to stack arisings in piles as you go. You can rehandle with them if you are careful, but it’s not ideal. They are heavy under a tilty, and can be slow due to restricted oil flow, but it does give a great deal of manipulation if necessary (not massively necessary if just reducing height along a hedgeline, but handy if breaking down the canopy of a tree for example).
In hardwoods a shear will often struggle to cut near its capacity - you’ll have to lever/cut/recut a few times and ultimately use the machine to break the cut section off. This sort of abuse won’t do a tilty sandwiched in the middle much good (you are better off direct-mounting if working near capacity).
Yes , we have considered a saw biggest issue is the cut off limbs fall in any direction and potentially into the neighbours or back on the machine .
Best solution is a LSCCDI...... Benefits of a LSCCDI are that you generally don't have an expensive paperweight kicking around, nor the additional insurance or risk liabilities.
Let some clueless c.... Do it.
I've looked at both in the past. Reality is unless you have a huge amount to do on your own farm (I'm talking a 500 acre plus farm with 6 acre fields all overgrown) and you want to do it over the next decade it's significantly cheaper to let someone come in.... It doesn't work properly as a contracting model unless your already doing that sort of work..... Plus your competing against people who have got 50% RPA grants for the equipment.
Thanks, it’s going to be used on a Kubota U56, so weight is a big factor.
Purchasing a tree shear is looking like the best option currently, but I’m very tempted to have a go at designing a simple grapple saw. Being able to section up material after it’s been removed would be a big benefit.
With the Kubota’s maximum auxiliary flow of 75 L/min, surely a hydraulic saw would outperform using a hand chainsaw?
The main components would be a grapple, saw cassette and a rotator, whether that’s a gear or worm drive. Potentially, I could leave out the rotary union initially and just run longer hoses.
It’s not something that will get loads of use, but I’m sure either option would be handy.
MDE tree shears seem to be popular, as do the likes of Digbits. looking to avoid the likes of Hardlife and JB Equipment, as they appear to be Chinese imports
I have a tmk300 - Its not going to do a tidy job of a hedge 🤔 handy enough to use as a grab afterward though.
the wacker handles it fine even under the tilty and I rob the tilt from the engcon, but deff direct mount if using it for anything serious
They can be a paperweight like a lot of attachments, I keep advertising mine to sell , then another job crops up 🤦‍♀️ keep it for as long as ive a carrier machine seems like the best plan once you've got one sat there.
I've looked at both in the past. Reality is unless you have a huge amount to do on your own farm (I'm talking a 500 acre plus farm with 6 acre fields all overgrown) and you want to do it over the next decade it's significantly cheaper to let someone come in.... It doesn't work properly as a contracting model unless you’re already doing that sort of work..... Plus you’re competing against people who have got 50% RPA grants for the equipment.
Very true, although my sister recently had some tree shearing done on the farm through a grant, and I reckon a beaver would have done a neater job!
I’ve got a TMK300 on S40 you are welcome to borrow to play around with if your machine is on that pickup? (The pickup is welded/fabricated onto the shear so can’t be swapped unfortunately).
Thanks, we’re currently on 45 mm pins, but appreciate the offer!
Not sure how well this would work, but as a temporary solution, could the gripper on the back of a tiltrotator be used?
Either purchase a saw cassette or build one to suit. I can’t see why it wouldn’t work for smaller-diameter pieces, around 150 mm max, as long as you take it steady and cut in small sections.
I started building a saw unit a few years ago for a different project, so I’d need to finish that off. It would be nice to have a cassette that simply clips on, allowing you to trim off smaller limbs as needed.
You could definitely use the gripper as an accumulator if you are mechanically sympathetic.
Get it built - if you fancy doing something that would fit S60 give me a shout, I’d happily get involved (financially as well as real-world testing).
Is there any point of a tree shear on a 5/6t machine? Know a fella with one on an 8t and he said it’s a bit pointless. Don’t have the reach for decent stuff or weight to hold onto the heavier stuff.
If you do decide on a shear, make sure you’ve more than enough oil flow, if you don’t, you’ll not close the shear fast enough and you’ll drop/not properly hold what you have cut.
Id say so. I know JB are a bit scrapping the barrel but the video of this little shear on a 2.5t komatsu demonstrates well the kind of job where it's too much for a flail- but I'd quite happily sit there all day topping a hedge like this which would otherwise be a ball ache with a chainsaw to cut and clear. Everything will have it's limits
The op on that Komatsu is certainly one of the better demo drivers I've seen for a product- especially on an old dog of a machine.
I can understand, but at the same time a 13t with flail would soon have that down, but I understand not everyone has access to 13t machines and it may not be accessible etc. Horses for courses I guess
Just in the interest of balance, I’ve used several shears on 8 ton machines and on the right work they are very productive, but you’ve to match the kit to the job you’re doing same as owt.
There’s a hardlife shear here that I’d sell, yeah it’s not a omef but it’ll be cheap and we haven’t broke it, had it on 8 & 5 ton Volvos
ive brought down some fair lumps with the tmk300 on the 8t - certainly not a waste of time, but like sjs says its about the right job.
