Forklift Height Extension
't is a tall mast closed though :unsure: be alright in a hi-cube, but doubt it'd get into a std box
Op said 2.7m and it is 2.5m according to the advert.
Otherwise I think what op is looking for might be called a reach truck as opposed to a forklift and are typically used in warehouses. Might garner a few more options.
Nearest I could see with a quick look
Hello All
I wonder could anyone help? Im looking to get some more height on my forklift.
And I came across these mast height extenders from kool.
They seem ideal for what i want but ive had an impossible time atempting to purchase them. I beleve they just bolt on to your existing carraige.
Has anyone seen these or would know where I could get them in the UK?
Or better still would any of you guys be able to make them?
Cheers All
Probably no-one is keen to sell them because of liability. At a guess.
Yes but you'll not get a low mast reach truck...all designed for warehouses so not triplex
This one would give you 40mm of clearance. Again electric
got a mast here off summat similar to that, but instead of the mast travelling forwards, it was fixed and has a scissor set up behind the carriage, to put the forks forward/back ... adds a bit of weight to the lift / reduces the original truck's capacity a bit, I'd've thought :unsure:
IIRC came off a two tonner - skipped the rest of it in the 'clear out' :rolleyes:
By far the cheapest and easiest option though.
We do already have a second forklift, which does reach but its a pain having two of them in a small area.
Especially as the taller one of them can't be stored under our mezzanine.
I was hoping someone might have come across the piece of kit I originally mentioned.
Nope…
I think the potential for things to go wrong with something like that will mean you will only get it from the likes of Alibaba.
As a work around you could always get a set of rotating forks. Pick up a pallet that you want to handle and put it on the second Mez deck. Turn the forks 180degrees and pick the pallet up again and put it on the top Mez deck.
Kool are a respected brand of forklift gear though.
Good shout on the rotator! However, @V8Druid wilm be along shortly to tell you that forks are not rated for upside down use….
  • Smile
Reactions: CPS
In theory the ones on a rotator should be as if something ends hanging from them as you rotate it would exert the same force as using upside down.
