KX027-4, E27, SV26, and 26C-1
T
tim361
Evening all. My first post on here. I’ve recently sold my Multione and looking to replace it with a digger for my tree surgery/ fencing business.
I’ve spoken to most of the dealers to get pricing by being my first digger it’s a bit of a mine field. Have spoken to a lot of people who recommend the Bobcat E27. Seems to have a very good following, be pretty reliable, and the offer a good package. I’ve only ever driven kubotas and feel like it’s a pretty safe option and also the cheapest. The yanmar and the JCB are the hard ones. Not a huge amount of info on them that I can find online hence asking on here. JCB are my nearest dealer only being 30 minutes away, all the others are around 2 hours. They’ve also matched the quote that bobcat sent over.
Just after any reviews good or bad on the above machines. Would like to run a grab with rotator, flail and the auger for fencing.
Have a read through this thread. I don't think there's a "bad" mainstream machine out there but I would say If you're doing grab work I'd say go conventional tail swing, you'll want dual auxiliaries too for grab and rotate.
Not tried the JCB 26c if it's anything like the 8026 the build quality might be a bit hit and miss with paint although none of the manufacturers seem to do decent paint.
From my experience back up is excellent, lots of mobile fitters, all issues were sorted pretty quick. Haven't had any serious problems with my 8026 although it's not done a massive amount of hours
Have a read of this ...
T
tim361
Think I’ve probably read through that 2-3 times now.
The Yanmar dealer is Field and Forest, they’re in Scotland, I’m in the south east. They’ve got a depot in Hampshire so it would come through there. They’ve offered me the sv26-6 and the -7. From what the dealer has told me the -7 has a smaller cab than the -6. They’ve found a -6 they can do me but adds £2k to the price of the -7.
TVE is currently my nearest bobcat dealer with Versatile going bust in the summer. Dealer has been very helpful and knocked £2k off the price to get it inline with the others. Big plus with bobcat is the 0% finance which he can also add the forestry guarding and grab onto the 0%. Also come with a 3 year warranty.
Kubota comes through lister wilder. I’ve never bought anything through lister wilder but they’re a long established dealer. I’ve only ever driven Kubota diggers and have no complaints but have read that the hydraulic flow isn’t the best when you’re doing multiple things at once. Kubota offering 1.5% finance over 3 years machine is also the cheapest by £2.5k.
Finally JCB comes through Haynes. They’re an ag dealer near me who I used quite a bit for Stihl & Husqvarna bits. Nearest to me only being about 30 minutes away. Have matched the price of the bobcat machine with 3 year warranty but unfortunately no 0% finance. Also not having much luck finding over reviews or comments. Have watched Mr Gunns review but that about as much as I can find.
Wouldn't you be better off going to a JCB construction dealer for JCB rather than an agricultural dealer?
T
tim361
Thanks for the tip. Have just looked and the JCB construction dealer is even closer to me. Only about 20 minutes away. I’ll ping them an email and see about getting a price from them.
If your in the South East wouldn't Coplant in Kent be your nearest dealer? But yeah the new Yanmar does look to have a small cab, the -6 version is nicer looking but be aware that the boom does not offset properly to the left as most other minis do..
I think as @doobin will tell you Bobcat take the mick with pricing in the first place so the dealer is not exactly being helpful by reducing the pricing- he's just being a bit less of a piss taker! I can see that Bobcat probably does tick the boxes out of all of them though.
Wacker Neuson ET25 might be an option if you are after a towable setup with grab etc going from job to job alot. It's basically the same guts and arm digging power as their zero 2.7t but with expanding tracks which maybe useful if you are going into tighter gardens etc...
T
tim361
No Kubota is Hi spec one with the twin lines. Just re read the quotes and the Kubota is £2800 cheaper than the others. The more I think about it seems like the Kubota is the better option.
Maxus
I have the ez26 and it's pretty good. The twin auxiliary hydraulics run rotate and grab really nicely. The et25 is basically the same apart from its not zero tail, I would recommend making enquiries into it, it's a nice weight for towing as well, you should be able to comfortably stay legal.
The 25 has a narrower up structure than a ez26. I think the et26 is closer to a 1.9 on steroids, same category as a taekuchi tb225.
I thought that untill I saw and had a go on one. It would hold it's own against any 3 tonner for most things, and lift capacity over the side is actually slightly better than the EZ26 The only slight disadvantage is due to the expanding tracks you don't have the ground clearance like a fixed frame undercarriage. With a grab and 3 buckets on board you will be at the limit with it on a Ifor GH1054.
Not a fan of the new kubotas - like anything ok if you've not got a reference but noisy agricultural uncomfortable things compared to some and deff guilty of riding along on a long ago won reputation
Maxus
Yes your right, the et 25 is like a tb225 and it is smaller than the ez26. But the engine and hydraulics are the same. With a cab, ac, hydraulic hitch, a ditching bucket, fuel, I was 3500kg at the weigh bridge with the ez26 on a gh1054. Any additional buckets have to go on the vehicle, which is a pain, and why I'd say the et25 is worth a look.
If you have driven the Kubota and are happy that it will do your job then that’s where I’d spend your money, particularly if it is a better price than the rest. Don’t tie yourself up worrying about the others if you have first-hand experience of a machine that ticks your boxes.
My only experience with diggers on your list is the Bobcat E27 (not the Z version, which looks almost identical!). They are a great little machine, but you need the extra counterweight and some sort of written warranty guaranteeing the paint (which will fall off in sheets from new).
Drove this in Sweden a few months back (yes i know its an ET20) It handled the Tiltrotator very well and was rock solid over the side.
