Hg2702
Get that tm bought !
Solid forks rather that floatinggoing to get some pallet forks for et65 - any style better suited to under a tilty ? to shift pallets of pipe, ibc's etc ?
Can’t believe you haven’t got any! Mine go everywhere with the machine! I’ve no issues with the Engcon ones, fixed forks , chopped them up from s40 and made them s45going to get some pallet forks for et65 - any style better suited to under a tilty ? to shift pallets of pipe, ibc's etc ?
tiltys excel at fork use ..... main reason I built mine to use with .... put a pallet virtually anywhere as long as you can get 'em back out .. that and grabsyeah Ive always thought its more shite to trail round... but keep seeing a use so might get forks and be a proper tit and get a brush![]()
Yeah we dont do a lot of building type work so haven't bothered up to know but seems lately been handling ibc's to fill tanks and occasional pallets of cement and would like to build a simple pipe rack to save ratchet strapping a bundle of pipe together to place next to drainage beds etc.tiltys excel at fork use ..... main reason I built mine to use with .... put a pallet virtually anywhere as long as you can get 'em back out .. that and grabs![]()
Log IBCs....Yeah we dont do a lot of building type work so haven't bothered up to know but seems lately been handling ibc's to fill tanks and occasional pallets of cement and would like to build a simple pipe rack to save ratchet strapping a bundle of pipe together to place next to drainage beds etc.
Could cobble some up I guess as have an s40 headstock, but not sure its cost effective by the time you've bought forks etc
could either find a scrap 2-2.5 t FLT and buy the carriage and forks, or not that difficult to build a carriage - buying a scrapper is quicker thoughYeah we dont do a lot of building type work so haven't bothered up to know but seems lately been handling ibc's to fill tanks and occasional pallets of cement and would like to build a simple pipe rack to save ratchet strapping a bundle of pipe together to place next to drainage beds etc.
yeh - the above were an example of creating a set up from a std carriage .. have those 6fts, on a 20" carriage fit, a couple of sets of 4 fts on both 16" & 20" fits and a couple of sets of 3fts for each carriage size ... tend to use the 4fts the mostFixed forks are much better. Short forks are a good option to make it easier to pick up and drop off stuff near you without moving machine. Also reduce risk of pulling machine over by having the centre of gravity too far out.
Top tip when using them, if what you are picking up is too heavy the conventional way round turn the forks towards you and slide under from the far side. It is surprising how much extra you can lift.
I needed to trim the metal over the pins on both my sets to allow full rotation as they weren't specially made for a tilty.
216 punching well above its weight thereFew from the week retaining wall coming along 216 been handling 300mm auger very well to be fair to it considering its going 2.4m down in sticky clay. Just time consuming getting gear up and down.
Tb216 must be a stretching to get that out of the hole in a one-er.?Few from the week retaining wall coming along 216 been handling 300mm auger very well to be fair to it considering its going 2.4m down in sticky clay. Just time consuming getting gear up and down.
Got the reach to get it out just, did the last couple of holes of higher tier made it easier for sure. One of those jobs wish could have something bigger in but does show what smaller kit is capable of.Tb216 must be a stretching to get that out of the hole in a one-er.?
Blade gives a nice lift too if needed. Actually always found my TB216 was pretty good on the auger. Not noticeable different than the 3 tonner.Got the reach to get it out just, did the last couple of holes of higher tier made it easier for sure. One of those jobs wish could have something bigger in but does show what smaller kit is capable of.
