Grease gun head for duck prop shafts
I’m looking for a good option for greasing prop shafts on plant specifically my duck thwaites dumper etc . I hate lying on the ground having to try and get in position to get the gun to work so I wondered about these narrow head lock couplers or the needle coupler any one used them ?
Easiest way is to replace with a yoke with the grease nipple in one of the caps.
Otherwise JCB telehandlers use to come with a greasing adapter that was a grease gun chuck on one end of a piece of bent steel pipe and a grease nipple on the other. The pipe was bent into a specific shape. You put it on the grease gun and it allowed easy access of propshaft and axle uj's
What do you mean a yoke with grease nipple in caps ?
If only they all had them in the first place!! On a 3cx you had to jack them up and let the front axle hang down to open up the uj at least you could spin the prop to get into it!
That’s what I’ve done with all the ducks I’ve owned , trying to kick the tyre around to align the prop while laying underneath it but for some reason the Hyundai won’t let the wheels turn . I must be doing something wrong !
Auto dig lock ??
I honestly don't understand why they aren't more common.
A farm I used to work on had a grease gun in the cab of all their telehandlers. And every morning every evening and every time you filled up with fuel you would check the uj's and if the nipple was visible, grease it. Reasoning that if you checked often enough you would come across an exposed nipple without playing shuffling back and forth.
I don’t think it has one , it does have a work mode and travel mode though that might make a difference . Will give it a try later !
@drema has an auto system - PITA - locks the brakes and pendle axle when operating - never turn it on
That’s good practice , I’m going to mark my prop with some sort of shiny permanent marker with where they line up so I can see them easily just bending down .
For farmers they had some pretty good maintenance practices.
Everything got greased either every morning before work, or every time you filled up with diesel depending on how much use it saw. Every machine had a grease gun, a pair of gloves and a rag in the cab so that hydraulic couplers got thoroughly cleaned before connecting up.
Everyone got given a John Deere metal toolbox and every machine whether or not it was a John Deere, had a John Deere toolbox bracket bolted to it, so everyone took there own tools with them between machines.
