Sub 3t Excavator - towable
I think if i was looking again, I'd not be fussed by single aux if I was planning tilty upgrade. I'd just go full fat control system on the tilty and then you'd have everything you need including hydraulic hitch. Whether or not that's a good idea I suppose depends on your work, but if you're an owner operator on price work I think it's the way to go. As for AC I've used it a few times but it's not exactly luxury in the ez 26-2, more like you won't die, like a dog trapped in a car, if the windows are shut on a hot sunny summers day - which if dusty is actually quite nice - most of the time you wouldn't miss it i don't think. The wacker has been good for me so far, no complaints or anything I've found that is annoying.
Our local Wacker salesman himself was hardly appraising the AC system either. Said it kept the edge off but hardly ice cold- he also said he sold a EZ26 to a customer who like to use it like a 5 tonner- reckoned with the AC running you could notice a drop in power, sounds a bit far fetched but his words not mine
I’d imagine you would notice a bit of a drop off in power with ac on a small machine, it’ll defo use a couple of hp.
ac can take up to 10hp to run
Maxus
The seat in the ez 26 i have is springy and you set a dial to your weight, I wouldn't describe it as an armchair, but certainly not a school bench!
The seat Iin the ez 26 i have is springy and you set a dial to your weight, I wouldn't describe it as an armchair, but certainly not a school bench!
Yeah that's it. It might spring up and down but the actual cushioning is very firm and and doesn't absorb the buttocks!
Gonna say it but the AC is the worst thing on my hitachi, even on a sunny day last few weeks it felt warm in the cab, but it suffers from heat soak off the engine bay - Hitachi are looking into it, my opinion is there is inadequate insulation between the cab/engine.
I notice alot of minis are now putting the offset boom controls on the joystick. Yanmar, Wacker, Volvo bobcat all that way. This seems great in principle and when I have used it it's much nicer when just on bucket work, but was thinking when using the grab the amount of time im swinging the offset on the pedal- whilst working the grab in a tight spot think it would do my head in having to switch between offset and rotate/grab all the time
I’d rather have it in the lever , it’s on the floor in my kubota and I prefer the Volvo set up and you would soon get used to pressing a button on the lever to switch between the 2 . I had a button on the Komatsu to switch between tilt and grab when I had grab on and it was so fast once I was used to it
