Bobcat E10 track tensioner
P
Polecat
Checking a few things on the E10 while I was doing the greasing the other day & found the right side track to be a tad out on the tension whipped it up with the grease gun, then the left track was a little more its about a 33mm gap to middle roller.
But I can't get the gun on the nipple, it seems like the ram cylinder has spun a little & the nipple is jammed against the bottom metal plate of the access hole.
Is there any way I can spin it back round a bit without having to take the track off, access to the ram seems pretty restricted, ive tried to spin it a bit (carefully) with a small pry bar, but it doesn't want to move, ive not released any tension to the track as yet, as I didn't want to find out i couldn't spin the ram cylinder after releasing the grease, then I can't tension it back up.
As it is now, the machine is still usable
P
Polecat
See attached.
Catch 22. Unlikely to move unless you release tension.
Should only be a half hour job even if track needs to come off.
P
Polecat
Yep thought so.
I cant see a decent place to pry on the cylinder to spin it, when i release the pressure.
It does beg the question though, why has it twisted in the first place, has a peg snapped or retaining bolt come out, crap or stones getting lodged in the tracks & push it out of line.
I was just looking for a 5 min quick fix eh ;) :)
It’s not a major job to get the track off and tensioner out. Personally I’d want to know if there’s something put together wrong inside the frame, or something broken, otherwise the minute you lose a track on a job, you’ve got a headache.
Can you offset the arm, so the bucket rests on the track at the idler end? If so just put a bit of pressure on it and try move the adjuster!
P
Polecat
I’ve got a 1.5 tonne pull lift, or ratchet lever hoist as some call it, maybe i could use that with a sling round the track, do you think.
Swancott2007
Sorry to jump in on this thread but I had a track come off on the e10 the other day as I couldn't get the grease nipple to take grease,luckily got the track back on after fitting another(shorter) nipple which was fine for a bit and then it lost tension again,I'm just wondering if the length of the thread would be causing this?, I've ordered correct nipple and hoping the cylinder is not goosed!
Unlikely to be the grease nipple unfortunately. Doesn’t need too many turns of 1/8 npt to make a good pressure seal.
Check the torque and try again, you might be lucky. Or the piston may have stuck slightly when you last tried to pump it out after not being moved for so long.
