Proper gypo today @Monkeybusiness 🤣🤣
Every box ticked!!!
Transit van ✅
Irish plates ✅
Trailer full of brash on its way to a lay-by ✅
Indecipherable Irish accent ✅
At least 6 children ✅
If it looks like a duck, and quacks like a duck…
Feck, when you put in writing like that, its thought provoking 🤣
The only difference is i only have 2 children, but there's normally 3 or 4 of someone else's knocking round 😂
And the fact that every **** and there granny is out to the tip today and its taking an hours round trip to do less than 3 miles, the next load is very likely to end up in a lay by somewhere 😁
William127
William127
Carnage begins. M6 solid here. Chock full of grockles . Every assorted version of tin tent known to man plus the usual gaggle of dodgy looking van lifers.
Brilliant . Look at you like a peasant when your dragging an ifor rattling your way up the inside lane past em all 😀👋🏻
Someone has actually made themselves a Grocklebox 😆 🤣🤣
Not necessarily: half track fordson deathwheel anyone?🤣🤣
not as deadly as those NZ helicopter blade type things
similar to this but with two gert blades like rotors
not the one I'm thinking of but along the right lines
one I was thinking of had 10ft + blades and'd collected several hundred yards of fencing wire :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
this is very similar
https://youtu.be/XEx8Wn_8r-4
You’ve not seen the speed I work…. 😜
it'd only burn at a given rate though ;) and you'd need a long reach to feed it for a fire to reeeeally get 'chewing' through that lot at any decent rate :giggle::giggle:
