70mm 2 days working use Topps.
Opinions and thoughts.... Also any idea on a supplier for a 210-5 linkage pin? This one was new last month![]()
Looks like twist shear? Can the item rotate under load? It looks greased but I can't tell from the photos if the pin has been galling rather than twisting freely? If you are getting through them that quickly maybe a length of EN8 or slightly harder bright bar might give/bend a little more rather than shear like a hardened pin?70mm 2 days working use Topps.
Fixed pin, greased in all the right places and bolted into the grapple.Looks like twist shear? Can the item rotate under load? It looks greased but I can't tell from the photos if the pin has been galling rather than twisting freely? If you are getting through them that quickly maybe a length of EN8 or slightly harder bright bar might give/bend a little more rather than shear like a hardened pin?
exactly what I said to him earlier on FB PMs ... make a lot of pins out of 80 quidsworth of a 3 metre random BDMS lengthLooks like twist shear? Can the item rotate under load? It looks greased but I can't tell from the photos if the pin has been galling rather than twisting freely? If you are getting through them that quickly maybe a length of EN8 or slightly harder bright bar might give/bend a little more rather than shear like a hardened pin?
having seen both halves and the location I'd be erring on the side of ......faulty materials ,...........some better pix would've helped your cause though Rorytheirs what we have sent the manufacturer![]()
Yeh was thinking the same,having seen both halves and the location I'd be erring on the side of ......faulty materials ,...........some better pix would've helped your cause though Rory
They don't deserve better pictures, shitty piccys for a shitty producthaving seen both halves and the location I'd be erring on the side of ......faulty materials ,...........some better pix would've helped your cause though Rory
nah ...... 's the jam jar he keeps his frog spawn in, in the spring ... no residents currentlyDid you take those pics through the bottom of a pint glass?
do I see a slight bend here Rory ?????theirs what we have sent the manufacturer![]()
