70mm sheared pin.
70mm 2 days working use Topps.
Opinions and thoughts.... Also any idea on a supplier for a 210-5 linkage pin? This one was new last month 😬
Oh I will add, on a grapple, handling light iron 🤔 no beating down skip or crushing things! Literally just pick and place.... Can't afford to bang the grab as it's very intense on the ram. 😢
jd6820
jd6820
Looks like twist shear? Can the item rotate under load? It looks greased but I can't tell from the photos if the pin has been galling rather than twisting freely? If you are getting through them that quickly maybe a length of EN8 or slightly harder bright bar might give/bend a little more rather than shear like a hardened pin?
Fixed pin, greased in all the right places and bolted into the grapple.
K
Komatsu
If it was new last month, I’d maybe have a word with the supplier, see if they’ve had anything like it back?...bad batch maybe?
exactly what I said to him earlier on FB PMs ... make a lot of pins out of 80 quidsworth of a 3 metre random BDMS length
my first reaction was impact fracture ... but he says not ...... it looks to have been 'overcooked' :rolleyes::unsure: ... it'd be going back if it was mine, especially as it's done sod all .. apparently! :giggle::giggle:
started at the lower edge in the pic and spread around the circumference, 'fore the rest let go IMHDO .. effectively shattered :oops:
theirs what we have sent the manufacturer (n) 😂
having seen both halves and the location I'd be erring on the side of ......faulty materials ,...........some better pix would've helped your cause though Rory
K
Komatsu
Yeh was thinking the same, 👀...maybe a bit lighter
Did you take those pics through the bottom of a pint glass?
Mark
Mark
Was it a genuine Komatsu pin? Think I have one or two brand new genuine ones laying in the yard away on holiday at the moment though so can’t have a look till next Friday.
