Jimoz
Can you buy the rubbers for the chamber lids separately? Got a base, risers and lid and the lid is loose. Its either a full new lid or getting hold of them rubber tubes, or bedding down on compo.
I have a load of large rubbers in a pile of stuff I bought the other day... I can check if you want.. sent me a DM so I dont forgetCan you buy the rubbers for the chamber lids separately? Got a base, risers and lid and the lid is loose. Its either a full new lid or getting hold of them rubber tubes, or bedding down on compo.
Are the rubbers all standard? Its a polypipe lid and risers. Presumably if the brands are interchangeable the rubbers are all the same size?
Local merchant had them in same brand polypipe so picked up 4 to do the risers as well. Noticed they are using the same chambers on the job next door and they dont have any rubber rings knocking around. I bet these get left out in loads of installs if not included with the gear.
Merchant won’t include them unless it’s asked for - I’ve swapped to osma and they come sealed as standard, much better quality fittings.Local merchant had them in same brand polypipe so picked up 4 to do the risers as well. Noticed they are using the same chambers on the job next door and they dont have any rubber rings knocking around. I bet these get left out in loads of installs if not included with the gear.
