Odd bolt
Where do you get the 5 sided socket from to pull a Perkins injector pump to bits with🤔
Got a leak in one so going to have a delve 🧐
Just had a proper look and found a cheap set🤷🏻 see how it pans out🤔
What size ?
Citroen was a 19mm iirc on calipers. Wtf I dunno.
US pro/Bergen do a set for handy money and generally ok stuff . My go to for cheap stuff.
had the same issue with the bolts holding the injector pump on the side of a Hodna diesel running my big pressure washer years ago - 5 sided head ... IIRC I found a Whitworth ring that was a perfect fit
