Recommendations for Wire Crimpers
Have a little project on the go where I need to make up some 16mm2 cable ends. Lots of cheap crimpers about , but wondered if anyone had tried anything like these ?
Still on manual here 💪🏻💪🏻💪🏻☺️
Lmk.how you get on tho
eBay sellers never disappoint do they..."wedding decor" 🤔😂
ditto .... way quicker and easier than pumping the tish out of one of them and trying to keep everything where it should be
50mm2 is still a blunt-ish chisel in a V block :giggle:
0.5 to 16 ? I'd suggest they trying to much . Be damn un wieldy on 1mm
Yeah my little ones go up to 6mm2
Which ones do you use for 16mm2? Friend of mine has a cordless set 😍
Annoyingly I carry a £1500 set of press kit in the van, but you can’t get awg adaptors for the plumbing press guns 😞
Mines old version of this iirc
I'm away ATM so can't check but never let me down. I'm sure mine goes up to 75 though as I've deffo done some 75s on a Genny
For bootlace small stuff get the knipex if you feeling flush but recently bought another set of copy off Amazon and it's fine ..
looks much like what I have, on both counts
