one off design
River is up - raining sideways - no work so mancave time :)
I know its not the place but there is some good knowledge here
I would really like to put something like this
on this
its tricky because they are not parallel and ideally could be fixed at 3 points using one lower down
seems there is nothing out there for the old girl - if i dont sort something mrs is going to insist on another bike, sure i could have another bike but i really like riding this one :)
How do I best go about mocking something up getting something made 🤷‍♂️
Knock it up out of cardboard or corex, then its time with the grinder and welder. Or you go to a local engineering firm, but they want drawings really and it soon gets expensive
dont think correx or cardboard would hold form but yes that might be the way
Russell
What bike is it?
You could make one out of ply or mdf as a template and then re make in alli or plastic.
I thought about making one but decided to buy one thats folded incase i go over the bars and get wacked buy it.
The crf300l has 2 fixings either side that are not parallel like your one.
This is the one i got
This one would be easy to copy.
I think its just 2 verticle sides and then the top screws on to the sides
You could probably make that out of an old track mat maybe ?
its 1290 ktm superduke r
has to sneak alongside these panniers behind the stainless bushes that the panniers drop on, as you say I think with the kit I have to hand its an adaption job of something existing rather than start from nothing.
got any 1.6 or 2mm ali kicking about ... easy to cut/bend ... start with a card template, transfer to ali to get your shapes/bends then up it to 4 or 5mm ali?
looks a rainy day challenge :rolleyes:
would be better in ali I reckon
stay clear of tight bends in Ali though ... stress points ... gentler bends (or a series of lesser bends) last longer and stick the shocking they'd be subjected to ;)
tighter bends tend to split the material (often not visibly, initially)
Can you not use L brackets behind the pannier mounts?
