Homemade Tiltrotator - How hard can it be ??
jd6820
jd6820
A few more parts added to the build.
I still need to finish machining a few features on the blocks that house the rotation pins, along with drilling a 25 mm hole for the hydraulic cylinder mounting unsure how's best to do this ??
Slow but steady progress.
Ideally I need to find a decent second hand lathe at some point as it will make projects like this far easier for making pins and bushings.
View attachment 78727View attachment 78726
Fair play, some seriously good stuff going on there. From the update to CNC controller through to the drawing and machining of the parts. Something I'm just getting used to myself. Still working out how to utilise Fusion 360 and getting into the world of CNC machining. There are cheap enough lathes about that are in good condition. Just bought a Harrison Alpha 400U to hopefully do the bulk of the machining. Anything large I'll chuck into the old DSG (another cheap lathe at £2000) so they are about. Really enjoying reading these posts and keep up the good work! Have you any plans going forwards after Uni?
how much Z axis travel do you have? fix the component to an angle plate and bore them out ? ... soon get centre, touching off with an edge finder - only need to touch off on three edges, which you have
are you going with 'top hat' bushes? or plain?
been some incredibly cheap CNC lathes on FB MP lately (all with control faults, sadly) ... Way beyond my pay grade :cry: or I'd've been sorely tempted by one for 800 quid, in particular looked mint --- other issue with them is the footprint - 'kin huge :(:oops:
jd6820
jd6820
Yeah had to go and look at this one today just to make sure it was okay, they have issues losing parameters if the internal batteries die and then external power is removed. This one appears to be good. Ex college then to a small precision instrument repair company who mainly do one offs so barely used it. Ways are still like new, cant quite believe it really and the pictures online were terrible else I think someone else would have snapped it up. Like you say they have a fair footprint, electronics don't worry me too much as it is usually just a flat battery then servo's zero position is lost. Main thing is the older controllers being able to accept code and feeding them with it.
jd6820
jd6820
This lot doesn’t really compare with the complexity of the parts you have produced but does go with the machining theme. This was my over Christmas job x 2.
The wheels start out life as a solid billet of EN24T round bar 320 diameter and 150mm deep. End up with an OD of 305mm. ID is stepped the biggest being 140mm. Only just clears the cross slide. First cut is 5mm depth so I can get it to clear. Feeding at 0.30mm/revolution.
Cheers
Hopefully it'll document the build start to finish.
I am currently thinking of the possibility of building my own S30 coupler ?? Maybe once the have finished the build.
Make sure you can swap out the one you are going to weld in then!!!
Will_c
Will_c
Thank you @jd6820
Yes, it’s definitely been a bit of a learning curve with CNC machining. I use Fusion for my design work — the assembly and constraint tools aren’t great, but the CAM side is very intuitive and quick for programming parts.
I’ve seen a few Harrison L7s come up on Facebook , so I’m just waiting to find one that’s reasonably priced and not too far away.
As for what comes after uni, I’m still a bit undecided. I really enjoy both the design side and the hands-on, practical side of engineering, and it's difficult to find a role that allows you to do both.
I spent last year on working placement with Wacker Neuson, ( working Weidemann machines) as a design engineer. It was a good experience overall, but I didn’t particularly enjoy being stuck at a desk all day, which has made me think more carefully about what direction I want to go in next.
Will_c
Will_c
View attachment 78730View attachment 78731View attachment 78732View attachment 78733
Don't think the photos show the scale of these parts ... impressive turned on a manual lathe ?
Will_c
Will_c
Yes often seems to be the control system that gets outdated on most machines
jd6820
jd6820
Yeah, I was thinking that when I uploaded it. The lathe pictured is a 21" swing 12.5hp, it was running under some load taking 5mm DOC. No DRO so lots of measurements with calipers to rough it out then micrometers once near size and snap guages for ID. I do have some bore micrometers but none that size. Harrison's are a good lathe, maybe look a bit newer than L7 better with an M series, Colchester are also good lathes, plenty about too. DSG's are about the top and can be found for handy money but may have been worked hard as they'd be a lump newer to buy. If you are looking for a machine to suit turning on AG stuff then I'd be after a 16" swing, you've a bit of capacity then for larger bars/pins (through hole size is a big factor). I suppose I'm making the assumption you have 3 phase? The bigger lathes are usually cheaper as they aren't really home shop machines.
Will_c
Will_c
occasionally you see decent machines come up , ideally stuff that comes out of colleges tends to be alright as it hasn't really be used that much.
Unfortunately we don't have 3 phase at home currently which is a bit of a limiting factor
jd6820
jd6820
Thank you @jd6820
Could you do a field service type role? i.e. dealer tech support from manufacturer side? You'd basically laise with the dealer if they have an ongoing issue with a product or a problem they can't solve then you work with the manufacturer for a solution? You'd get office and field based work under the same role. Employed by say Wacker Neuson rather than supplying dealer. Krone have recently put job offers out for such roles. Based on what you have shown us here I think they'd jump at the opportunity to employ someone such as yourself.
Beutys them! What they for?
jd6820
jd6820
Ah, yes single phase can limit motor size somewhat even with a phase converter or VFD. If you are on a farm there is a government scheme that has put a cap on how much the electric companies can charge to install 3 phase. I know we didn't have it and the cost to get it was £83,000 before the government cap. We ended up paying £7,000 in the end and that was with the power company installing it as well.
jd6820
jd6820
Bridge crane wheels and drive shafts. Split the gearboxes down and installed the new shafts as the old parts had worn the splines in the wheels and on the driveshafts. These new parts have a mod so I don't think I'll see them again. I think an engineered wear point as new parts were silly money.
Will_c
Will_c
Yes its something we are looking into as there is overhead power cables that run across , these are going to be put underground , Hopefully when that happens, we can also get a quote to bring the supply down the pole and into a kiosk at the same time.
