We had same model (6ton swivel dual view?) last year and the fuel fill point is quite low. Quite likely lower than the water level in that photo.Is green beacon flashing![]()
It's definitely not mine, although couldn't resist pricking Grahs ears upHow long have you had the blade, Rory?
I’m not interested what They’re like to sit in, just what they’re like to operate.Personal opinion the Liebherrs are the best dozers to sit in..... Other opinions may vary.
Your job with cat sounds great, any jobs going?I’m not interested what They’re like to sit in, just what they’re like to operate.
tbh I haven’t tried a Liebherr dozer and it’s a good few years since I was in one of their tracked loaders. I’ve been emissions testing in a D5 (what was the D6N) and it’s the nicest Cat I’ve been in by a margin. 3 speed auto and locking torque converter.
Any more pictures of the job?
I don’t tell you about the crap parts. I’ll be retiring in 2028 if you’re still interested.Your job with cat sounds great, any jobs going?![]()
Ooh is that a genuine Takeuchi seat cover you've treated her to?How many Taks get to work in two national parks at opposite ends of the country?
Small scale extraction today. Nice morning for it.
Eagle eyed!Ooh is that a genuine Takeuchi seat cover you've treated her to?
Have you still kept the Plastic on- I do hope so!Eagle eyed!
No eBay special I think. Nicely made TBF
Gotta keep that storrsy factory quality seat in pristine condition!
It's never been off ! Definitely the most pristine seat in history of Dartmoor diggersHave you still kept the Plastic on- I do hope so!
It always amazes me what others spot!!Eagle eyed!
Me too probably easier on a computer or tabletIt always amazes me what others spot!!![]()
Just showing off his fancy winch ...How many Taks get to work in two national parks at opposite ends of the country?
Don’t know how liebherr’s system works but the settings sound similar to the Cat hystats. You can preset forward and reverse ground speed independently and all that does is set the displacement of the pump. No physical gears. (Some Cat hystat wheeled loaders have a mechanically shifted drop box - you have to stop to shift ranges)Same thing? That said I suppose most do actually just sit in it and don't do bugger allIn all honesty I don't think I've sat in a more comfortable machine of any type and part of the reason is to give my wrist a break for a week which I have achieved. Cab nice, comfort, blah. She's a 2016 so older than you'd realise but James keeps them right. Previous tractor was a D5N with the nice brake turn paddles.
The drive takes a little getting your head round and I suspect it depends massively on the operator how you choose to drive it. I personally stick it in eco, push the stick right forward and use the decel still for feathering into piles or finer grading (TBF that's a lie, rough grading) you limit travel speed by setting upper limits on your gears. I tend to have 1st at 4kph, 2 at 6 and 3 at 7. Not sure exactly how the "gearing" works and have been told conflicting things. I'm inclined to believe it's just upper limits on the hystat but never actually looked it up. Might now you've piqued my interest.
Maintenance wise, blade has grease points. Main blade frame bottom assembly is supposedly sealed for lifeall in all (she is kept at lowish hours) I don't think there has been much issues. A sensor here and I think we had a issue with the chains (similar to cats system 1 but German) that was rectified under purchase.
Not taken many pictures of the job. It's boring wet and cold. Basic Key trench put in last year and layering on top at about 200-300mm before rolling and repeating. Benching into hillside where suited to step key it in.
Not sat in a brand new Cat or Kommie. Last one would have been a T so a few years back. But as said 2016 lieb would take some beating in my book. Talking to Lionel about his one the other night he is impressed as well.
Yes sounds about right.Don’t know how liebherr’s system works but the settings sound similar to the Cat hystats. You can preset forward and reverse ground speed independently and all that does is set the displacement of the pump. No physical gears. (Some Cat hystat wheeled loaders have a mechanically shifted drop box - you have to stop to shift ranges)
The decel pedal can be set to slow the engine then apply the brake, or slow the ground speed at constant revs. I hardly ever use that setting. You push the drive lever into position and either use the decel pedal or you can change ground speed on a thumb wheel on the go. There are settings for implement response, steering response and forward/reverse modulation. I doubt many regular operators use the slow or soft settings, too boring.
That thing never fails to impress . Great bit of kitJust showing off his fancy winch ...
... joker![]()
The rope on ours didn’t last very long (and I keep forgetting to replace it!). On the right job they are brilliant machines.That thing never fails to impress . Great bit of kit![]()
