Looking for 16' tiltbed trailer
Just to conclude this.
Had to take the side kit as none in the country without, and will have to add the chequerplate myself.
Sides can go into storage and will look mint when it comes time to move it on.
What's going on that Doob? To short for LB?
Anything and everything. Mainly a tractor and implement or the loader and buckets, as the Ifor gh1054 is perfect for the diggers.
Log bullet fits on the Ifor and this is an inch longer so should be easy.
Starting with this. An absolute pleasure to load even with the oversize wheels. Drop the ramp and pull the supports, no messing about.
£6400 plus vat. They’re going to send on the supports for the ramp holder that go on when not using the sides
If you are using all the time then looks to absolutely worth the extra money over the IW. You cant beat a IW LM or TT for versatility... buts its certainly sub optimal for daily loading and unloading with ramps or a mesh ramp.
Starting with this. An absolute pleasure to load even with the oversize wheels. Drop the ramp and pull the supports, no messing about.View attachment 75960
Gotcha. Perfect and fully get you with an implement
Ahar, thought LB needed 18ft 👍🏻
Ive said it recently but IW really need to up their game on the flatbed department- theyre still churning out stuff from the 90s. Clattery, crap tie down points, dreadful ramp stowage design,
The other manufactures are all way ahead in terms of fit and finish imo. The plant trailer is Ifors saving grace.
