That's a fiver each from you 2 in the kitty please?you pair should be on a stage ---![]()
So in this case you'd have to switch between grab and rotate?View attachment 75663View attachment 75664
View attachment 75665holes in the end are Pressure and Tank (supply and return) -- holes in the top are where you want to send the oil to A or B - 3 pairs (open / close cylinder for example)-- holes in the front face are where the solenoid valve bolts on to - outer 4 are bolt holes - inner four are P, T, A & B ...
depending on which solenoid (a or b) is activated depends whether P goes to A or P goes to B with neither operated there is no flow to either and the oil flow in the
manifold just circulates -- it basically takes a flow, whether constant, proportional or on/off and redirects it to whichever location you want it to go -- one supply can be directed to as many outputs/services as you like (three in this case - three way/gang manifold)
6 x 2 diverters are literally just that and work either way -- P1/P2 are your two service lines - with the solenoid dormant P1/P2 go to ports C & D with whatever is connected to them (say a rotate circuit) - with the solenoid energised the shuttle in the valves body re-directs the P1/P2 to ports A & B and whatever is connected to them (say grab) - the oil will flow in either direction in these but they do need a case drain (open, unrestricted line to the tank) for the leakage within the valve body or pressure builds up and the solenoid can't overcome it
with a 6 x 2 diverter - yes - with a **t*p 3 set up and suitable manifold to carry them, you can feed both services together from the one supplySo in this case you'd have to switch between grab and rotate?
I think you could use the horn supply on the right joystick to control a diverter to switch between offset boom and the other service, Saves switching manually?Just divert the offset to give you an extra pair of pipes down the boom. Then fit a rotator. I’d go with a fixed rotator rather than a swinging type.
That's a tenner pleaseI am with Lancs lad ,cetops is magicary stuff ,
I am pretty good at most things mechanical but the hydraulic wizardry that is cetops 6 x 2 is beyond me
Looks funny now it meshes together! Is there a reason you've fitted it that way round, I always had it so the hoses were facing me coming towards the machine so that I could keep an eye on them...Ok...I know this isn't the first time it's come up
But what's cheapest way to convert this to a rotator? Even feasible?
Only basic hammer piping off pedal. Incredible useful as is but being able to rotate would be a game changer for our arb stuff.
Don't say get an EC
when I fitted the 6 x 2 diverter on Lil' Jake, to use the crowd/bucket ram, to open close the Haner, I put a switch in the dash, to swap between the horn or the diverterI think you could use the horn supply on the right joystick to control a diverter to switch between offset boom and the other service, Saves switching manually?
twenty - he mentioned 'em twiceThat's a tenner please
not gonna get much smaller than the one I put up Aiden .. but yeh, saves a pipe run, up the boom/down the dipper, doing thatA smaller rotator with 6/2 diverter mounted on the head bracked
But wouldn't that mean switching between grab and rotate?A smaller rotator with 6/2 diverter mounted on the head bracked
Yes. Trust me, you don’t want that.But wouldn't that mean switching between grab and rotate?
The answer is sell the whole setup and buy a 320 Takeuchi..... You then get joystick rollers and a free visit from an annoying plant journalist of your choice
who’s had the visit?![]()
Yep. Food for thought. . .does that help anyone?
The horn doesn't work ...What's the warranty againI think you could use the horn supply on the right joystick to control a diverter to switch between offset boom and the other service, Saves switching manually?
is that a question or a statementWish I hadn't asked ,how control 3 services? Tb 125
