BackhoeQ
After some help/advice please
2017 JCB 3CX Contractor (3500hrs) is cutting out under load above 1500rpm, no stuttering just shutting off, ignition stays on just stays "Stop now" gives code P025300. "Injection Pump Fuel Metering Control A Low (Cam/Rotor/Injector)" Will start straight back up when you turn the key.
Will drive fine and do inclines in all gears as long as you don't push it too far past 1500rpm. It will also cut out if cycling the front loader and dead ending the bucket at full revs after circa 50 seconds.
Noted it seems to get worse in the warmer weather. Operates absolutely fine otherwise. Doesn't seem to be getting any worse, this has been on going for a few months now.
So far i have:
Changed all relays - starter, lift and power hold, checked all fuses on the machine. Battery gives good voltage and good voltage on the lift pump, the lift pump is still running when the engine dies.
Changed the lift pump and filter for a genuine, along with the secondary filter, fuel is crystal clear and blown back into tank, no obvious debris. I'm getting 2.3ltr off 2 cycles both at the lift pump and after the 2nd filter.
It has been plugged into service master and passes tests with regards high pressure pump and pressure on the rail etc...
Ive changed the IMV as service master points to that. Changed the fuel temperature sensor, pressure sensor and had a leak off test on the injectors which showed 2 letting by so had them all changed but no joy also had the common rail changed again no joy.
Engineer ran it with a new TMAP sensor from his van which made no difference and the TMAF sensor is clean.
Checked wiring harness but no signs of damage, there is 12v to the imv and a 5v signal.
Any suggestions would be greatly appreciated as you can probably guess i am beyond frustrated. The next step would changing the high pressure fuel pump but wondered if I've missed anything obvious? Service master suggests bypassing the fuel cooler but not sure if that would affect the fuel delivery as its on the return.
Thanks in advance,
Jonathan
So far i have:
Thanks in advance,
Jonathan
