Hoses looks wrong for a tiltIs that a tilt bucket ? , could be a hydraulically driven weed cutting bucket ....might have to wind up the big screen![]()
Looks tilting to me. You can see the pivot pin with a hydraulic ram going to it...Is that a tilt bucket ? , could be a hydraulically driven weed cutting bucket ....might have to wind up the big screen![]()
Are you getting a you know what with your next tilty ?Chucked some gravel around yesterday.. no cheating beam this time! Just a fettle with the rake. Don’t normally get this much time on the machines, makes a nice change!
A free hat?Are you getting a you know what with your next tilty ?
To be fair any other tilty I get will be for a larger machine, this one would just get refurbed and put on the replacement machine.. can’t see that happening for sometime though! Local Engcon dealer has just had a new 8ton kubota with full setup on it, so I’ll just rent that if needs be!Are you getting a you know what with your next tilty ?
Oops got confused with left hookerTo be fair any other tilty I get will be for a larger machine, this one would just get refurbed and put on the replacement machine.. can’t see that happening for sometime though! Local Engcon dealer has just had a new 8ton kubota with full setup on it, so I’ll just rent that if needs be!
I do look like a right hooker in your defenceOops got confused with left hooker![]()
Predator snack bar, serving sandpipers.Sandmartin nesting area? I’d have thought it a bit too easily accessible to predators though possibly.
Ah thespiens I would have looked if with an LAn amphitheatre for fellow Thespians?
Thats it. I suspect the same, but the chief twitcher consultant says anything over 2m, this is 2.4m at the tallest.Sandmartin nesting area? I’d have thought it a bit too easily accessible to predators though possibly.
Those little buggers were all around as I finished off this morning- didn't take them long to find it!Nesting site for mason bees
Could look really good on cost per habitat space created![]()
