Probably because the previous owner believed JCBs ‘500 hour grease interval’ bollocks!Brass will cut out easy enough? I think these are the optional extra ‘long life’ bushes.. not sure why they haven’t lasted very long on your machine though?
machine a stepped drift ?These type. Brass with delrin studs by the look of it. Gave it a few taps but I’ll just end up chewing it up.
What’s the best way to remove? And anyone got a link to replacements? Bought some spring fit steel ones off eBay but these look a better design. View attachment 68929
I’ve got the same bushes on my machine.. I’ve greased it more than 3 times… and it has barely any wear at 1300hrs!Someone on here or ce posted up an article that said they prematurely wear if you grease them to normal schedules. And possibly if you use the wrong grease
I’m going with lack of grease for so much play at 380 hours.I’ve got the same bushes on my machine.. I’ve greased it more than 3 times… and it has barely any wear at 1300hrs!
Souldn't even need a stepped drift.machine a stepped drift ?
On brass?…does not the line of weld up it ,not work ?
my eyes are shite ,shall put glasses on and look,On brass?…
worth pointing out these will be 1-3/4 inch not 45mm i.d... any standard off the self bush just might not fit if the od is differentBought some spring fit steel ones off eBay but these look a better design. View attachment 68929
