Bit of a shopping list.
Simon edwards
Simon edwards
I am on the lookout for some additional kit due to our workload,if anyone has seen any tidy examples a heads up would be greatly appreciated.
I’m after a 6 tonstraight tip dumper,ideally with lights and registered,budget 10k
5-6 ton excavator ideally older Kubota u55,057 or if really tidy a u48,budget 25 but would go a bit more,needs to be tidy,would consider other flavours .
Finally after much consideration a 12-13 ton plant lorry,or flat bed to convert to a Beavertail,need ideally 7 ton payload,budget 15k.
Thought I would ask you guys as it puts a lot of informed eyes out there.
This is now available if anyone interest( not yet cleaned it up)
keep em peeled,cheers.
Simon edwards
Simon edwards
Thanks I am thinking it might be worth a shot, never been to a big plant auction before.
Might entertain a swap for a self powered tracked 2 way screener with absurdly low hours 🤣. The KX 61-3 that I’m supposed to have have use of in exchange for storage seems to be remarkably absent so far 🙄
Cheers monkey, sadly not really in the market for a screener, but the little 61 would last the rest of your life playing around your estate🤔
Makes me sound like a minor lordling. Sadly I merely posses almost an acre of Class 4/heavy clay Devon land . I do however count myself lucky to do so.
KX would be a wonderful accessory mind you!
Deposit is just a hold, have a search on their site they have explained it abit better than they used to, it uses put a lot of folk of over the years as you always had to put 10k down! I once had a 250k limit which was scary when you get carried away!
Ok will do. Always thought it was 10k or something.
Ta
