Decent wiring diagram for 3CX ?
Scraperman
Scraperman
Which starter did you order?
Without a doubt, the costlier reduction-drive type is well worth the price.
Originally I was going to order this one : https://vicaryplant.com/products/motor-starter-714-40159?_pos=1&_sid=acbf33b8a&_ss=r but was told that for an extra £10 this one had more torque and so this is what I have ordered : https://vicaryplant.com/products/motor-starter-714-40531?_pos=1&_sid=901aa3376&_ss=r I have also been told that because the latter is shorter than the first one it is easier to fit.
Scraperman
Scraperman
Is this your machine, serial no points to a 1993 machine over a 2003?
Either way the blue relays are the same, so if starter still plays up just pull the corresponding one out and see if it stops the starter.
That's a bit worrying ! The V5 says first registered 01/11/2003. and that I acquired it on 23/03/2007 !
This is my machine :
Scraperman
Scraperman
Ah yes deffo a p8, I think they went up to 1995/1996 before going into a p12..
yours probably just got road reg in 2003 not actually made then!
Oh damn, you are right. Date of 1st Reg. is 01/11/2003. Thank you for your continued help.
Scraperman
Scraperman
Now this is going to sound really very stupid but when you mention relays are they in the fuse box or elsewhere ?
Scraperman
Scraperman
Just box. On a p8 they are near the seat under the side dash.. (hopefully!)
Thanks again for your help. I'll have a look tomorrow and see what I can find. I've had to go into the fuse bos a few times but that is under the front dash on the RH side as you know.
Are any of the cables colour coded ?
Yes - they are yellow! (all of the wires are yellow).
It's not that bad though - each wire is numbered, so its exact function can be identified.
From the diagram below, 810 and 815 will be printed on those wires.
Suggestion - take a pic of the fuse/relay box before you start pulling anything. The Blue and Green relays are not interchangable.
yeh -- JCB like yellow wire - A LOT :mad:
Scraperman
Scraperman
Thank you for that information. I will indeed take a photo. before I move anything. I find that because of my awful memory loss these days I have to do that prior to taking anything apart. I used to have a brilliant memory but as I've grown older, certainly since I passed 75 a few years ago, it is awful now. Except of course for silly things like vehicle registrations from 60 years ago. o_O
Next time you go to start it, get someone to give the solenoid on the starter a smack with a hammer while your turning it over, there’s a good chance it might persuade it to engage!
Or the starter is full of brush debris is finding hard to turn, i would probably take it apart and clean it first👍🏻
