I had a hitch like that ready. But I guess you’re still having to compensate with tilt as you rotate, as well as switch from tilt to grab. And the grab on the tilt divert and most likely also the worm drive rotator will be slower than a dedicated rotator. It’s amazing how quick I can pull and windrow scrub with a grab a rotator- and also how much of it I have to do!I’ve got an angled headstock on the old Rototilt (ie Cranab) grab on the 6 tonner - that’s how Rototilt supply them. Gives you a horizontal grab at ground level for ragging out stems/shrubs when oriented the right way around.
Rightly or wrongly I was seeking to recreate the setup I have on the e27 that works superbly. Grab/rotator combo under quick hitch, and tilty under quick hitch when required for bucket work. Breakers, rippers, bulking buckets all under quick hitch no tilty.
The plan was always to have both- I’ve just ended up getting them in the other order than envisaged! Need to get this machine out and earning some money.
So if anyone spies a secondhand s45 top/bottom four pipe titly, let me know!
