K
That’s more like it.Just seen this on facebook
Gotta give the labourer something to do!!Manual bottom hitch though![]()
And no extra service (so can’t use a grab etc under it, buckets only).Manual bottom hitch though![]()
Thought we couldn't find any in the other threadGotta give the labourer something to do!!
Only time I've had something fall off the end is when the labourer has done it. Yes I should of checked but he'd done it 5 or 6 times a day for the 9 weeks I'd been on hire to them at that point.Thought we couldn't find any in the other thread![]()
no -- there's no rotary coupling - would be wiser to rob rotate, thus preventing you winding up hosesYou would have to explore the cost to add hyd hitch minimum before you pulled trigger, grab if you only did a bit you could rob tilt couldn't you.
Lovely day for it here
