Hi my name is bob I used this site a few years ago and found it great . This time I need to find the ignition switch wiring for a terex hd850 2001 tha
Bob dale
Hi I’m trying to find a ignition switch wiring diagram for a terex hd850 2001 machine thanks
can't be the Bob Dale I know .... been dead about five years :rolleyes::giggle:
Hello again Bob ..... hope you look in more than every few years ... you might find it both informative and entertaining ( - not always in that order though) :ROFLMAO:
Bob dale
Hi thanks for wiring diagram my switch wiring looks correct but when I start it up the starter Moter keeps turning any help please
could be a physical cause to that .... try attempting to start it with the fuel/engine stop engaged (so it can't start) - if you let go of the crank position on the key and it (the starter) continues to run it's an electrical issue holding the starter engaged.
(possibly a faulty solenoid holding)
if it stops turning over it's likely to be hooked teeth on either the starter dog or ring gear retaining the starter pawl/dog in the engaged position.
