Volvo Mini Excavator- erc48C Swing Brake will not release except with thumb activation
V
volvoerc48c
This has to be simple but my excavator swing brake will not release with any machine function except for me activating the thumb which is the boom angle as well. I have used a volt meter and I am only getting voltage to the swing brake solenoid which I think is mounted on the back side of the vertical bar when I press the thumb function but then it locks the swing brake after 5 seconds.
Any volvo or swing brake experts have ideas?
Remove the two connected wires to the solenoid for the thumb see if swing brake works?
V
volvoerc48c
thank you Mick - the - fitter, I don't have a manual nor wiring diagram so i am not ware where the solenoid is for the thumb? Anyone have a manual or location?
Try this one first, pull the wires off, tape them so they don’t touch anything!
Oh yes well spotted Gra, I went for that as it looks like a bolt on item!!
Maybe the one bolted behind, as the hose coming to the right hand 90 looks a bit odd beyond!
When you say Slew brake, do you mean as in a switch you flick to brake it? or when you go to slew the slew not releasing?
I could be wrong but I don't think you'll have a solenoid for the slew brake
Ok, Had a look in the manual, This is the "Slew brake, pressure sensor"
It takes its signal from that back into the Vehicle ECU
I stand corrected i was wrong,
The slew solenoid is mounted behind the bar, MA9402
'Drema has one - solenoid failed and it was locked solid :mad: .. bloody annoying and took some sussing/finding
could've failed internally then -- again had a very similar looking one fail, but that sh*t itself all over the floor, so was an easy / deffo bollo-ed find
