There is a sensor in the hitch that detects the pin of the bucket. My it is adjustable and quite easy to do. Unfortunately my big machine is on site so can’t take a pic. If you drop the bucket off and send a pic of the inside of the hitch I can probably point it out. Might only need a little turn of the nut adjuster.
I reckoned to check and all seemed in order under there but will have another look tomorrow 👍
If it's a proximity sensor it doesn't take an awful lot for them to require adjustment.
When I was younger I maintained a static baler in a factory that worked near enough 24/7. Due to how much it moved and it not being a very smooth machine the sensors for certain parts needed constant adjustment.
Looks a lump up there !
Browsing whats left of the old photos with a view to finally starting a bit of a "what goes on here" thread ...- lost a lot with a failed hard drive :(
"And it was all yellow 🎵🎶 "
I'm sure I've said it before when I've seen your pictures but the 802 and 802.4 were decent machines. The 803 from memory was always too heavy from a towing prospective but again decent.
Is the middle one of the 3 bigger machines an 8027 or an 8032
Its an 8027 and was a dud tbh, got it from an expat going back whom I used to do jobs for over here and even drove that machine a bit for him, paint was tatty on the metal parts so resprayed those bits, it was prob the worst mini jcb made imho, was reliable but digging envelope terrible and wouldn't track along without scratting if you were cross track, didn't keep it long but the French loved a JCB as they had a great reputation back then(which has gone unfortunately) so did well on it.
Of the machines in the picture I ran the 806 / 802 / 801 - I bought 2 x 801's and kept the best, selling the other paid for the transport + maybe 1/3rd of the one I kept.
Bought the 802 from the firm I left in the u.k as I drove it from new.
Paid 10k for the 806 and I remember thinking how much money earning potentiel was in that 10k machine when it arrived, it had a inj pump issue, the fellow in u.k who I bought it from (knew him well) paid for the repair and then we had 4 or so pretty trouble free years with it, obviously a very basic machine and not comparable to the wacker et65 but wasn't about netflix ..even a hydr hitch was rare :) that one had a manual 3cx hitch and used cheap 3cx buckets, it was all about getting going for minimum outlay.
Liked the simplicity of the machines back then compared to now, when you were new in a foreign country,limited language, in the sticks with no contacts, simple was good.
C
Cal919
Gave the new chainsaw a good run out this afternoon. Used 3 x 4ah batteries and one 2.5 just to finish couple of cuts. Think it did well considering its only a little top handle. I do have 8ah batteries but wanted to try it with the 4’s as thought would be more comfortable with it being a top handle. Could of done with something with a longer bar for bottom as well but managed. Just need to get the machine in to grub the stump out.
Had a quick look at hitch and will no doubt show my ignorance.
So pins in front of jaw tell you you have something in front jaw but not locked in as the front bucket pin pushes them in and breaks contact from the switch inside.
inside hitch it pushes a rod away from magnetic switch - so when you close hitch with a bucket on and lock it off this rod in front jaw can't return because of bucket pin in front jaw, so how does it s
ense hitch is fully locked off safe ? Can't see another sensor anywhere 🤦‍♂️
View attachment 67855inside hitch it pushes a rod away from magnetic switch - so when you close hitch with a bucket on and lock it off this rod in front jaw can't return because of bucket pin in front jaw, so how does it sView attachment 67858ense hitch is fully locked off safe ? Can't see another sensor anywhere 🤦‍♂️
Something to do with the magnetic switch?
Rod that turns alarm off via magnetic switch can't return because front bucket pin is in jaw.
There must be another sensor to let the control unit know the rear pin is located and the hitch is closed - the front pin sensor can’t offer any safety-critical information alone.
It’s got to be what looks like a proximity switch adjustment in the lock cylinder make up (number 2 - although there are two number 2s for some reason?!..)
That might be clearer... rod is pushed through jaw by front bucket pin which activates switch and alarm comes on - pin can't return though with a bucket on so something overrides alarm when back pin is in jaw.
