3 Cylinder Perkins
union139
union139
JCB Perkins 3 cylinder with hydraulic pack 25 to 30 years old in storage, what machine would it have been used in.
Regards Steve.
union139
union139
The Perkins engine was used to test the suspension set up rubber mounts. Then put in storage for around 30 years.
Steve
lil' Jakie 'praps Steve ... if the pumps have been run dry they'll likely be shot :(
L
LKSF
Pennine Hillbilly
Would need a shot of the other side, but at first glance it looks like the one in my 803.
There are quite a few different cubic capacities versions of that engine series, that all look similar from the outside.
You would need the code of the plate by the injector pump to ID its size. I`ve got a feeling there may also be a series number cast on the side, reading 103 dash something.
Rob65
If it’s for a JCB 801 it will be a 103-10 engine. I think if its for a JCB 803 it will be a 103-13 engine.
union139
union139
Many thanks for the information that you have supplied. I will try to remove the lower timber section to observe the plate.
Kind regards Steve
union139
union139
union139
union139
Many thanks Craig
union139
union139
I found this picture, after the Christmas break I will enter the information that is on the plate.
Regards Steve. PS all have a great time 🔧
