you gonna seed the bank? 's gonna be all over the gravel otherwise :rolleyes:
We used this stuff recently green mat 200 soil growth membrane
we'd ran out of non uv stable pipe waiting on delivery
the 63mm mdpe is the rising main from the pumping station from the garden room (poo pump)
Hope no one accidentally taps an outside tap into that one in the future 🤣
I’ve used MDPE for pumped waste quite a few times myself. Nice and non restrictive
Giles, it just shows you what's needed to do the ground work for a house extension. Amazing really. 1 of the pictures I thought you had been flooded but then realised its the concrete
there is 1 where morning after pour it chucked it down and we'd dammed the drain trench so the concrete didn't got down it and crated a small boating lake until we dug out the clay lump wed plugged the trench with
Start of a new job today. Digging back this farm entrance which I'll stone face. Got a load to do along the drive/approach to farm too
Done no more to this entrance. What I didn't know when I started it was every half an hour a massive fendt and dump trailer was going to be coming in tipping at the farm for 4 days in a row, no point attempting to do anything whilst that's going on. On the plus side I started another section out the way and have a feline helper now.. oh and the contractors have bogged the dump trailer a few times now so have to go and dig all 20 ton out the back before any chance of it coming back out🤣
It’s not a nice feeling when they go down.. not so bad of they go down level, at least you can tip and get a little tug out! 🥵
nice looking mog :love: ..... Squeak used to spend every day with Reo when he was here doing the wall :giggle:
Ended up mixing our own saved around £100 so not a lot in it but more control and less waste. Plus have around 4t of aggregate left for more concrete
I quite fancy that self sufficient idea to mix dry for tanks but don't have anything to drive the pan mixer and you still have all the hassle of getting aggs and cement to site, then cleaning it all out ...can't see it happening as opposed to getting 3m3 or so from the plant in the truck.
Apparently we are getting a "béton self" shortly which is supposed to be a self service concrete dispenser,which in theory is a choose your mix, pay and back under ....is that a thing in the u.k ?
I think there were a few builders merchants looking into it but I think most of the users would be cluckwits. Imagine some of the transit brigade!
It doesn't work out much cheaper but for tank bases and awkward areas it works better for us. Pump and 3m3 would have been 1k!
