For Sale Intermercato TG16 EG selector grab.
you surely not using the Cranab off that truck? must be 200+Ks :oops: .. I'll bet it's on its toes :LOL:
No, the one off my 6 tonner (which is approx 150kg and quite a bit smaller than the one on that truck, plus the Rototilt which is a fair lump too on a little digger).
On paper this tilty fits this machine (fits 2.5-6 tonne) and the Bobcat handles it well but you need to keep your bumhole-monitor switched on as it can get tippy quickly when using the grab enthusiastically... It is also mounted under a quickhitch which doesn’t help, but ticks my application boxes.
If I was spec’ing it as a stand-alone machine I’d go for a smaller tilty (you are as well fitting the smallest unit applicable to your weight category, they are bloody strong!) but this digger has been set up to share attachments with my Takeuchi so I can trailer it to smaller jobs and chuck timber about/run the mulcher etc. It’s not likely to do a lot of digging to be fair.
could you get away with some extra ballast and still trailer it?
It’s got the extra factory counterweight on, but another hundred kilos plus would be welcome!
I’ve not stuck it on a weighbridge yet (ignorance is bliss...) but I know it is on the limits of legality. Everything below the quickhitch travels seperately!
..... but no defence, in the eyes of the law :(
ahh but you’ve got a high-vis on the back so all is well:ROFLMAO:
3ft un-marked ... 10ft marked ... rear overhang .... must be illuminated after lighting up time :giggle: ;)
