Yeah 2540 3200 is I thinkThink M&M were about 4K for a new one of these IIRC?
M and m ? Doubt it for a 400kg one think they’re about £10-12k from memoryThink M&M were about 4K for a new one of these IIRC?
Was going to say. At £4k I'd be down to M&M (local Wacker dealer) to pick one up this afternoon!M and m ? Doubt it for a 400kg one think they’re about £10-12k from memory
my big dpu70-100 at 756kg has x3 or x4 times the compaction force of my 1600kg 800mm twin drum roller,Think it's probably going to have to be a ped roller for me for ease of self loading on trailers, plus prefer to use over a plate. Like the look of the Mortimer ones. Few and far between for used ones about though. £8k seems alot for something that might get used a few times a month at best.
Sorry it was the DPU 2560 that was 4K ish IIRC. Only 170kg.Was going to say. At £4k I'd be down to M&M (local Wacker dealer) to pick one up this afternoon!
Flattening the Sphere of the Earthmy big dpu70-100 at 756kg has x3 or x4 times the compaction force of my 1600kg 800mm twin drum roller,
theyre different animals these wackers are for like roads and yards when you need to flatten the sphere of the earth a bit they aren't mixed bag things for tarmac etc like a ped roller
I don't use mine much but when I do its mega, our 200kg units get used a lot and im looking to add a 400kg that could get on a roller tailer behind 1 ton dumper for trail/footpath work
ped rollers are ok but not comparing like with like and any slopes etc ped's get interesting
£18k I think the 800kg remote one is £24k newSorry it was the DPU 2560 that was 4K ish IIRC. Only 170kg.
Wonder what the really big beastie costs new then ?
Not a bad buy for a preloved one at less than £3k then I guess? Mine has the remote receiver on it but no use for me .£18k I think the 800kg remote one is £24k new
mine does as well and I have the remote for it but only works when trio'd up as you need the others to steer withNot a bad buy for a preloved one at less than £3k then I guess? Mine has the remote receiver on it but no use for me .
Seen this one? No idea if genuine or available though.Think it's probably going to have to be a ped roller for me for ease of self loading on trailers, plus prefer to use over a plate. Like the look of the Mortimer ones. Few and far between for used ones about though. £8k seems alot for something that might get used a few times a month at best.
Some cheap stuff on there at the moment. That transit is a stealsome big wackers in this ... 24hrs to run and very cheap ATM (as usual though)
Gateway Auctions | Contractors Plant Auction, including National Hire Company Machinery
bid.gatewayauctions.com
I've got a 2540 that is being a pain to start sometimes it pulls flawlessly and others it pulls like it has no diesel and there's no white smoke from the exhaust. I've had the push stop to bits and I thought I'd found the problem as it was sticking but this morning it's back to not starting
