Dressta TD16N bulldozer
Abito TD16N
Abito TD-16N..what do you think of this crawler?you would consider it as design, you think it is efficient
Without operating one I’d guess they are hard to hold grade with.the blade being so far forward, doesn’t look balanced to me.
Vis must be good tho?
Fox bringing them in under liugong up here
I haven’t been on a dozer that size, Cat or Komatsu, where you can’t see the corners of the blade, if you can see that much, you know where the rest of the blade is.
quindi immagino che non lo compreresti e come trattore agricolo che prestazioni pensi che abbia?
Italiano:
Italiano:
TD-9
The Dressta TD16N being put to work in the UK. The hydrostatic transmission and pushing power puts in a great performance and is always praised by the operator. Get a demo from our dealers if your in the market for a 20t class dozer. ?''
would you buy it as a work companion to support you in your activities?? do you consider it reliable, what do you think of the line and the shape of the front adjustable blade bulldozer blade?' thanks I would put a large plow on it to break up compact and stony hilly terrain and make terraces with steps. am I wrong about the intended agricultural use??
