Thwaites 3ton Dumper
Scottie
Any suggestions for freeing the brakes.....?
Not locked, but stops quite quickly when freewheeling!
Handbrake operates a slide over rear axle, lubricated, seems ok.
Foot brake doesn't return fully, but when manually returned doesn't make any difference.....?
has it been stood up, or just started doing this ??
and welcome to the forum
bobthebuilder
one i know of ,the shaft in the front axle which applies the brakes seized in the hole ,copius amounts of wd 40 and a lot of wiggling to and fro ,cured the problem
What model is it? The changed things around, front axle brakes or rear axle brakes, swivel skip or straight? Photos if you like👍🏻
Scottie
Rear axle brakes, swivel skip.....
Can't see any shaft for the front brakes - ref. earlier comment
Richard
