Bobcat
jodb69
jodb69
Hi All
So Bobcat t2566
Started it up last week and started to drive straight away, felt like revving it too hard to get it going on an incline, same in forward and reverse (hardly moved)
Thought something not right..
Following week or so was fine..
Come this morning , same again but worse, would barely move.
There is a switch named 'Work' on this machine that turns from sensitive throttle to less sensitive for site work (for the want of a better word, im sure the experienced guys know),
Anyway once I moved the switch it seemed to work OK, I operated the machine in this switch mode for an hour or so , then switched back to the mode that didn't work and it seemed to function??
Switch fault or hydraulic?
I guessed not hydraulic or it wouldn't work in the other mode?
bobthebuilder
blue work switch and move the forward ./reverse to position 2 for road work ,blue switch down position 1 on lever ,for site
jodb69
jodb69
Bob
I always have mine on speed no.2 and work switch engaged (south), always worked until recently but a bit concerned I lost drive drive twice now
bobthebuilder
Bob
no i have mine on 1 ,and switch north for site ,there is manuals around
jodb69
jodb69
jodb69
jodb69
Hi All
So still having the same problem with the Bobcat having to rev the bollocks off it to get it to crawl in the morning , then it sorts itself out and is fine for rest of day.
Yesterday as I was driving it it was doing it's usual crawl ( prob about half speed and response time) on high revs and all of a sudden it was like a switch flicked and it went into normal mode and was flying around.
I'm kind of guessing this isn't hydraulic due to how quick.iy changed.
Are there solenoids etc that I could check?
Any ideas?
Cheers
Hi All
Any ideas?
Cheers
Sounds like a good place to start for sure. Possibly the solenoid for work mode is getting stuck between ports?
