Bomag & Benford Whacker Plates
O
Old Operator
Couple of Whackers - big one F -N - R mechanism does not work (seized I think) but good Hatz 3.8 HP diesel. I no longer have a 3C to move & lift it. Will manually move with lifting frame & engine removed. This is how I moved it last in small van. Smaller Benford I inherited from my business partner. Had been left outside with broken exhaust so water got into bore of Honda 5HP. So this either needs a rebore or clone Chinese clone engine to work - Vibration mechanism OK - Both machines all parts there. Pity to scrap but having to clear my late Dad's place My engine crane will lift big whacker base so van / trailer can back under
Would the hatz engine fit wacker dpu2540 does anyone know?
O
Old Operator
The big Whacker is a Bomag B9R 30/38 D, Hatz type E673 LS according to what I can find it is 280 cc 3KW / 4HP , 3,000 rpm max, was a current model in 'What Plant' yr 1999. has inbuilt centrifugal clutch
I am about to lose my workshop if dad's house sells in the auction - so space & time at a premium, it is a bit big for anything I would now ever need. You would likely need a 3t mini to lift it (as opposed to a 3C) Fear getting it apart then nowhere to continue the work.
Little whacker I might save if no one wants it. Clone engine about £100, so would it be worth the hassle of a rebore & new exhaust? Even this is a heavy lump by todays standards. OK for self build, might put it by for later. Hoping to get a retirement place where I can keep & work on stuff. Transition phase difficult
T whiting
T whiting
Definitely not worth messing with the honda engine just buy a new one and slap it on no hassle there only about £300. I did similar to a Wacker plate that had worn the crank out to the point there was 10mm of play in the big end
What throttle is on the big one I’ve a big bomag wacker and need a new throttle cable for it? Can’t find one, had one made up by one Dave jcb recommended but they didn’t do the little geared cam that goes on the cable that the lever reacts on
O
Old Operator
To tell the truth the throttle lever was not connected - you had to increase revs on the engine. Re the T. Whiting machine it is in a lot better condition than mine (& smaller & lighter, I will measure width & length of platen that whacks the ground tomorrow) Mine might be only worthy of a clone engine to get it going. There were some 'compactor engines' with a thicker engine baseplate even among the Loncin stuff but cannot find one now. As to mine I do not know if it was a 'bitzer' ie the GX 140 engine may not be original. My business partner bought it off a dodgy set of brothers - & said do not do a job with it outside the cop shop!!
BTW how much is a small petrol whacker to hire for say a weekend or week these days (inc vat) - this would give mean idea of if it was worth spending on
The platen base on the little plate is 19'' wide by 18'' front to back - not the smallest of them
