Awesome bit of kit for wet stuff. Go anywhere. Contractors starting to use tracked slurry gear up here nowView attachment 64748www.facebook.com
Run a flail nice I should have thought. Got to be a slow horribly drive on anything hard though. Bet it hasn’t got a 40k box! Useful weapon for someone and seems overly cheapAwesome bit of kit for wet stuff. Go anywhere. Contractors starting to use tracked slurry gear up here now![]()
Looks cheapView attachment 64748www.facebook.com
Guess the blade is to help you out when you start sliding down a steep grassy field with those rubber tracks !?Looks cheap
Could be looks ok for the moneyGuess the blade is to help you out when you start sliding down a steep grassy field with those rubber tracks !?
Think of a four digit number.....What sort of price are the tracks for them?
I think someone else has bough that cause I saw an advert for something agri services with that tractor in the photo.Cheap until it needs work or tracksI very nearly brought one with front flail and rear trimmer last year but just not worth the agro.
It’d be a rough ride pushing with the sprockets at the front. Track bunching.1000 or 9999 ?![]()
I'd noticed that and wondered about the wisdom of the blade's locationIt’d be a rough ride pushing with the sprockets at the front. Track bunching.
