Dougie
Hi, I’ve recently purchased a second hand Kubota KX27-4 for some ground works at home. I’m new to all this, so learning as I go along. I’ve discovered that the standard buckets for this machine don’t fit as its been fitted with a Martin MH03 hydraulic quick hitch.
The Martin website advertises this hitch for 3 ton machines, but the buckets I’m finding seem to be limited and are often only for 1.5 ton machines.
I’ve a number of questions I’m hoping you can help with:
1) Is the Martin MH03 hydraulic quick hitch any good?
2) Why would you fit this rather than one that is the standard size for the machine?
3) As most websites advertise attachments (buckets, etc) by machine type, where is best to find MH03 fittings as many of the website don’t allow this search?
4) Why am I finding the sizes are limited to 1.5 ton machines (Rhinox buckets are a good example)?
Thanks for your help!
