Bucket Repairs
Regy53
Regy53
I like cake
Hi All
We have a ditching bucket for a JS160 that has been used as a breaker?
The bucket itself is good apart from the usual bottom which needs a reweld.
Anybody recommend? I suppose its usually local guys? never had a bucket repaired before
cheers
Ross
mart1602
been trying to change the cutting edge on my grader fair play to geith whoever welded it on did a good job.spent hours with the grinder and plasma cutter and still cant get it off looks like nothing holding it on but cant even pull it off with the machine,wish ide of sent it off to someone now
wee_gus
wee_gus
Hi All
cheers
Ross
Where are you Ross?
Sounds like a case of cutting the arse out and welding in a new section and a decent cutting edge, not a big job can be time consuming at times though
be lucky to get an edge off with a plasma Mart:( ..... gas axe job ;) ..... wanna be a BIG plasma to blow through the thicknesses involved :oops: ..... used to do a lot of buckets :rolleyes:
Hi All
cheers
Ross
Where are you Ross?
Aye, no such thing as a quick bucket repair:rolleyes: only a good one ;) ....... or a bad one :( in the wrong hands :mad: ....... you need a recommendation Ross .. (y)
need one of these .....
or a set of these ..... to do a decent job
wee_gus
wee_gus
It’s doable probs looking at spending 4-5 hours labour and the cost of the material.
I’ve re-skinned far worse
not a difficult one Ross ..... someone's rubbed the back out of it, 'grading':LOL: .... bolt on edge, so'll come off real easy and either bolt a new one on or weld it on - cheaper option .... the bottom's easy enough, but'll need the facility to either roll or multi bend the radius into the back as it comes around ;)
a suitably equipped fab shop'd do it in a reasonable time at a relatively modest cost .... compared to a replacement, even a decent s/hand one
want their arse kicked, whoever did that to it :rolleyes:
Regy53
Regy53
I like cake
Yes, it’s for a js160 so I’m sure a new one will be about a grand, not sure if just to advertise as is or tidy the bucket up
out it as it is Ross ... let someone else deal with the problem ... or replace it :rolleyes: ....... or advertise it without and 'could always chuck it in' as a goodwill gesture :);):rolleyes: (y)
Regy53
Regy53
I like cake
out it as it is Ross ... let someone else deal with the problem ... or replace it :rolleyes: ....... or advertise it without and 'could always chuck it in' as a goodwill gesture :);):rolleyes:(y)
I think i will do these, it has a decent loading bucket with it so thats a start.
How do op's get away with it? is it seen as good driving as it saved loading a pecker up or what?
Danny
Danny
Sealing up heaps, back of the bucket on stone its a wear part at the end of the day and will wear out (y)
Probably be about £400/500 for a new skin i would of thought.
have to disagree about it being a wear part Danny ;) ... it's the body of the bucket ... as Mark said ... a few wear strips welded on additionally would be wear parts :rolleyes: the cutting edge is there for ground contact, whether it's the leading edge or the flat face underneath ... the body is for load carrying/containment
Mark
Mark
The straps strength the bucket as well stops them bashing the bottom up.
So strips across the back are classed as wear strips so surely if they aren’t fitted the back of the bucket is a wearing part:unsure: even my buckets get thin on the back, I don’t bash my buckets but they do wear:)
incidental wear and tear is inevitable Mog , but the addition of wear strips'll maintain the bucket body far better than none .. and yes i've always known them as sacrificial wear strips .... usually stitched on, to aid removal / replacement ultimately . ...... used to do a lot of 'em ;)
the back of the bucket is still the body though ... wear parts are usually more easily replaced :rolleyes:
Mark
Mark
now that is a repair ..... :cool::cool:(y) ...... some work gone into that ;) ..... and would not want the bill for it either :eek::eek::(
Was in the region of 8 or so grand should last another good 4 or 5 years now though. Was originally build in 2007 and last 2 machines with some repairs and addition of wear straps.
