My poor old jcb
Self builder
Just to say hi to everyone on the forum. I have used the forum several times when trying to fix my poor old jcb 801.4 (1996). I have been building my house for several years now and the old jcb has been great. I have repaired it many times, usually just blown hoses. A few days ago it threw one of the tracks and I've been trying to get it back on for a few days now. The problem is that the track adjusting screw is rusted solid. I've tried just about everything I can think of....heat, oil, big spanner....all to no avail. If anyone has any ideas I would be most grateful......thanks a lot.
Steve
More heat. If you're trying to use a blowtorch it won't be enough.
Self builder
More heat & bigger spanner… get some bulldog dbx soaking into it as well..
Thanks for your reply. I used a plumbers torch, do I need an oxygen acetylene burner ? And what is dbx? Thanks DAVID BUT.
Ok working on the theory the track came off and you are refitting the same track, get yourself a ratchet strap, place the track that’s off on the driven sprocket end, place the other end in a place where it would be against the idler end, using the ratchet strap put it around the top half of both tracks across the frame, put a bit of tension on the ratchet strap, drive forward on both tracks at the same time!
Self builder
Where about in Cheshire are you
I’m in northwich if you are close and get the idler out I will loosen the nut
I'm at the Crescent off London Road.
The nut is difficult to get at/loosen, see pictures.
Self builder
