Jcb 3cx manual quick hitch repair
Mavrick150
Hi guys,i am located in the West Midlands and looking for a company that repairs or refurbs worn manual quick hitches as mine has excessive wear in the jaws and locking plate pivot points ,any suggestions ? Thanks in advance (Dave)
Hi Dave, not sure about your area, but a good machine shop would be worth asking as they likely could. One point to make is you may pick up a manual hitch as cheap as a repair would cost!
For eg, this one on ebay
diggerjones
diggerjones
Is it as bad as this one ive been on.
Might struggle reworking it, if its a genuine 3cx hitch, as they where cast iirc :unsure:
cast steel though Craig .... very weld-able :giggle:
I took a a massive amount of slop out of the one on JakieB 'fore I sold it ..
pivot bored out to a more sensible 32mm and fresh pin fitted, grub screwed and grease nipple fitted, together with a packer behind the spring to take all the play out ... gripped like a lobster afterwards ... had I been keeping it I'd have given the hook jaw some attention with the hot stick/MIG too, to lose the wear in that ;) plus it got a new set of spring bushes and pins (y) ... made a massive difference to the bucket's stability
WP_20210615_15_55_51_Pro.jpgWP_20210615_16_31_30_Pro.jpgWP_20210615_17_40_30_Pro.jpgWP_20210615_18_05_04_Pro.jpgWP_20210615_18_05_08_Pro.jpgWP_20210615_18_05_15_Pro.jpgWP_20210615_18_05_38_Pro.jpgWP_20210615_18_54_13_Pro.jpgWP_20210615_19_05_01_Pro.jpgWP_20210615_19_23_43_Pro.jpgWP_20210615_19_49_59_Pro.jpgWP_20210615_19_50_10_Pro.jpgWP_20210615_19_50_15_Pro.jpg
took a 3 ft bar to get it to let go afterwards and a bloody good flick to latch it
Sell it and buy a new one. Although I bet new ones don’t sell for £300 these days 🤦‍♂️
DaveS
Good Morning/Evening fellow members
I have come across your post while searching for information on a
JCB Quick Hitch I recently purchased at auction in Australia
Having no previous experience in manual hitches I cannot work
out how to even open the locking jaw!
The hitch will be fitted to an excavator (hopefully) and I’m hoping someone can advise
me how the jaw opens.
Photos are attached
Your assistance will be greatly appreciated
Cheers
Dave Stevenson
Photos are attached
Cheers
Dave Stevenson
a few more pix of the relevant end and underside would help @DaveS :rolleyes:
DaveS
Gday V8Druid,
Thanks for the reply
Welcome!
Yep, you'll need to make a handle to engage that socket.
My QH is the same style as Druids above, so there is nothing to get in the way when engaging the handle.
Yours will need a longer spigot to get into that mouse hole, but he principle is same.
Once engaged, you lean on the handle, the bucket disengages from the moving jaw, the bucket rolls forward, drops out and lands on your foot.
From memory, I used a Φ19mm bar for the spigot welded into 800mm of gal pipe
View attachment 31310View attachment 31311View attachment 31312View attachment 31313View attachment 31314View attachment 31315View attachment 31316View attachment 31317View attachment 31318View attachment 31319View attachment 31320View attachment 31321View attachment 31322View attachment 31323
There’s your answer🤣someone who could repair it👍🏻
Gday V8Druid,
as the guys have said above ... gonna need a good piece of steel, with a pucka fit in that hole, then extend it once clear of the hole in the body with summat a bit larger (y)
Once engaged, you lean on the handle, the bucket disengages from the moving jaw, the bucket rolls forward, drops out and lands on your foot. 🤣🤣
[/QUOTE]
